Ebay Sketchy???
Old Nov 30, 2007 | 06:55 PM
andrewc_11890's Avatar
Ebay Sketchy???
http://cgi.ebay.com/ebaymotors/25HP-...QQcmdZViewItem
This seems way too cheap and probably like it will mess up my truck.
Anyone know anything on this?
Old Nov 30, 2007 | 07:01 PM
MercedesTech's Avatar
e-bay is always "buyer beware". If it seems to be good to be true, it probably is. I am not sure on your specific item or seller... but beware! I don't trust e-bay all too much, never been ripped off tho. Does the seller have reviews? If so those tell a lot about how they do business, if not then steer clear (IMO) good luck!
Old Nov 30, 2007 | 07:04 PM
Ftruck05's Avatar
Junk
Old Nov 30, 2007 | 07:42 PM
hivoltagefx4's Avatar
2 words: STAY AWAY!!!!!!!!
Junk indeed!
Old Nov 30, 2007 | 08:05 PM
JackandJanet's Avatar
Originally Posted by Ftruck05
Junk
I'd have to agree with this opinion. It IS "too good to be true"!
Possibly, looking at what are called "spec's" it changes your fuel/air mixture a bit. Makes the engine run a bit richer, which possibly gives you more power at the expense of lower MPG and higher emissions.
Somehow, it reminds me of those "fuel atomizers" you stuck in your fuel line upsteam of the carb back in the 70's. I've noticed they've made a comeback recently - guess you put them upstream of the throttle body.
An engine tune is not a "one size fits all" proposition! Go with Troyer, Edge, or any other one you see talked about here in "glowing" terms.
- Jack
Old Nov 30, 2007 | 08:13 PM
Bootleg837's Avatar
That is a .25 cent resister it tricks your PCM in to thinking its colder out then it is so the PCM adds timing and Fuel (Don't use it BAD BAD BAD)
Old Nov 30, 2007 | 08:57 PM
jk007's Avatar
It's a 5 cent resistor you can pick up at any radio shack or electronics store. It's suppose to trick you computer into thinking it's colder out, so the engine performs better. It doesn't work, you'll eventually f up your truck.
I tried it 5 years ago in a Ram 1500 and it did was trip the CEL.
Old Dec 1, 2007 | 01:58 PM
Ok thanks guys, no way i'm getting that. I saw it and was like .... that looks sketchy, not gonna trust it, but hey maybe it is reliable. well obviously not
Thanks again
Old Dec 1, 2007 | 02:36 PM
green06F150's Avatar
Registered User
I bought a similar one for my Chevy truck...just for fun....only benifit I saw was...after installation...I knew my "check engine" light worked save your money..
Old Dec 1, 2007 | 06:46 PM
So, in the spirit of "True Labeling", it should be sold as a "Check Check Engine Light Device"?
- Jack
Old Dec 1, 2007 | 07:52 PM
Raatikainen22's Avatar
- Jack
