Edge
Old Nov 14, 2007 | 09:23 PM
varsitymojo's Avatar
Edge
I have a 2005 F-150 STX 4.6L 2WD. I have a K&N cold air intake. I am getting a magnaflow catback, Limited Slip rearend, Jet Performance Module, Headers, And Grantelli Mass Air Slow Sensor. Will the edge work with all of this?
Can the edge recalibrate the speedometer and the ODOMETER?
And Can you get a custom Tune for it? If so how?
Old Nov 14, 2007 | 09:39 PM
MGDfan's Avatar
Everything but the JET (you can't stack tuners), the MAF ( which will skew yer MAF TF and hence wil require custom tuning to correct), and you may not be able to compensate for any leaning out the CAI may cause or exacerbate ( some 04', 05's had factory lean issues).
Speedo/Odo recal = YES.
Old Nov 14, 2007 | 11:22 PM
I have had the CAI for over a year and there is no leaning out, but you said the JET wont work and the MAF is pointless too?
Can you get a custom tune through the edge? if so where from?
Old Nov 14, 2007 | 11:29 PM
MGDfan's Avatar
And you know it's not leaning out how? Did you measure it? A CEL or lack thereof is not gonna tell you. ONLY direct controlled measuremet will confirm whether or not you have an issue here. Period.
Edge custom is available - DP-Tuners, I believe.
Old Nov 15, 2007 | 09:05 AM
05supercrew's Avatar
That is correct, Bill is the only one that can do custom tunes on the Edge.
Old Nov 16, 2007 | 01:07 PM
I know it is not leaning out because I had it tested, thanks!
