edge help :help:
Old Nov 7, 2007 | 02:08 PM
600Polaris's Avatar
edge help :help:
i am running level two with the timing and WOT fuel up (im running 93) and WOT shift points adjusted, i am getting 12mpg. i put it on level three and i am getting 14.5 with the WOT up and shift points/firmness. i was hoping for a tune combo out there that will give me better gas mileage. i drive a 98 with a 4.6, im also noticing level three is running better for me now, but i would like to know a good tune for level two and three because i tow frequently in the winter. and three for when i drive highway. any help would be appreciated.
Old Nov 7, 2007 | 08:16 PM
600Polaris's Avatar
ok, its worse, im down to 10.5 mpg....please help me out. its gettin expensive. im on level 3. its killin me and my wallet.
Old Nov 7, 2007 | 09:36 PM
Ftruck05's Avatar
Running LVL3 is not costing you anymore than running LVL2. Say you have a 20gallon tank, (87octane) 20gal@$3.00=$60.00 20gal x 12MPG=240miles (93octane) 20gal@$3.20=$64.00 20gal x 14.5mpg=290miles
In reality you are paying $4.00 to travel 40+miles. Keep running the good stuff man!!!
Old Nov 8, 2007 | 12:56 AM
600Polaris's Avatar
i run 93 on both but i got the big tank...35 gallons...the extended tank. but these prices are killin me, if i could get 17mpg id be the happiest ever.
Old Nov 8, 2007 | 05:33 AM
Kevin24's Avatar
What was your MPG on the stock tune before you added the edge?? When was the last time you did a tune up????
Old Nov 8, 2007 | 10:18 AM
600Polaris's Avatar
i was getting 17 before the tuner. yes i have had a tune up this fall for the winter and i change the oil every 2000 miles. the truck was more efficient w/out the tuner but much more of a truck with
Old Nov 8, 2007 | 10:19 AM
600Polaris's Avatar
by the way how does your exhaust sound because i think im changing my flowmater out and i like the look of yours. add an x pipe the dual it out.
Old Nov 8, 2007 | 07:18 PM
Kevin24's Avatar
Try running it with no custom options with the minimum octane required for that tune. Normally they get better MPG with the edge. Yours must be in pretty good mechanical condition or you would not get 17 MPG. I don't know if you will be able to get any better than that?
I love my exhaust. I have gone through many systems and this is the only one i am completely happy with. More power all the way through the power band and sounds awesome. I get compliments all the time on the sound. I need to make a soundclip!!
Old Nov 9, 2007 | 10:30 AM
600Polaris's Avatar
ill give it a try im goin on a hunting trip this weekend so i will let you know how it turns out. i was gettin 17 and wanted to be back up there. the truck is in great mechanical shape for now, i let my kid brother drive around (he likes to take it on a date over his car, i wonder why?) so ill see how long that lasts...and can you tell me about those maggie mufflers? the part number and everything because i plan on switching to true dual soon.
Old Nov 13, 2007 | 10:50 AM
600Polaris's Avatar
i did it and got 16mpg so im set.
Old Nov 13, 2007 | 05:36 PM
Kevin24's Avatar
Cool
Oh and if you click my mufflers in my gallery the part## should be listed.
If you do a little tweaking you may get more. Which level are you currently running??
Old Nov 14, 2007 | 06:41 PM
600Polaris's Avatar
i am running level three now because i found the best gas mileage on that level. i have done some tweaking, but if you got some advice ill be glad to hear it.
