do these tunes sound good
Originally Posted by king ranch
yea it just stays at 100 i did that for about 10 miles trying to pass a avalanche and couldnt do it just stayed right on his tail he was toped out at the same too also i was wondering what can i do to get better throttle response i hate how when i hit the gas all the way it takes a second to take off it revs up and then jumps really hard and hauls how can i get it to just take off as soon as i put it to the floor
OP - set yer Rev limiter to 6,000 rpm. Keep the truck out of O/D.
Be advised that your tires are NOT speed rated, so if one lets go... it's your fault. You have been warned.
BTW - yer WOT shift points are a tad low - 1>2=5400, 2>3=5300, 3>4=4800.
Reason - you need the slightly higher rpm so the shifts land in the power band, next gear up.
ok well i am worried bout blowing up the engine that seems a little high to me when do these trucks redline. i had them set at 1-2(5250)2-3(5250)
3-4(4800) and it got really loud on 1-2and 2-3 so i put them down to 5000 on both and left the 4800 alone i was scared it was reving too high
Loud how - exhaust, intake or what? Do not expect quiet at those revs.
Time for you to use the Search function and gain further insight.
