What wire to use for tach install?
Old Jul 20, 2007 | 02:21 PM
s1037s's Avatar
What signal wire do i use for an autometer tach signal on my 97 f150?
Old Jul 23, 2007 | 10:42 AM
s1037s's Avatar
btt nobody here ever hook up an aftermarket tach? where is the wire?
Old Jul 29, 2007 | 08:43 AM
s1037s's Avatar
bump again
Old Jul 30, 2007 | 11:48 PM
mrainey889's Avatar
Sorry, I don't have the answer to your question, but I might be able to point you in the right direction. If you bought a standard, plain-jane, tach, you may need to return it and do some research before you buy the next one. Most generic tachs are designed to hook to +battery, ground, usually a seperate +12V line attached to your headlight switch (for night time illumination) and one more wire to be connected to the negative side of your coil.
That's the catch, your truck has coil packs or COPs, depending on if it's a 4.6 or 5.4, no single coil, so no single negative side of the coil.
That said, I believe the tach output for these trucks (assuming a tach was in the dash) comes directly from the ECM. What wire it is I have no clue, but I am sure someone on here could point you in the right direction. What the electrical signal on this wire looks like I have no clue. It might be similar to a coil's low side output, but I doubt it. Either way, I believe that is what you need to track down. On possibility that could be an issue... Since obviously your truck did not come with a factory tach, it is possible the tach ECM wire is not present in any wiring harness. This might have been a way Ford saved a few cents... Copper cost money, and when you produce a few hundred thousand vehicles every penny counts. I'm not saying that is the case, but it is a possibility to consider. Even if the wire is not there, you could see about getting a junkyard wiring harness, extract a pin and some wire (easier said than done without an extraction tool), and insert the pin on the proper mating pin of your factory ECM.
For your sake, I hope I am wrong and this is simpler than I imagine, but I doubt it based on the lack of responses you have seen. Someone else was asking about this topic a few weeks ago, but the name has left me. You might do a search and see if anything was ever found out.
Mike
Old Jul 31, 2007 | 07:06 AM
s1037s's Avatar
thanks mike. it does have a factory tach but it is not working correctly,and i thought i could just tie into that wire but i was not sure if it uses a modified signal or not.
Old Jul 31, 2007 | 02:46 PM
JMC's Avatar
JMC
25 Year Member
Find the tach lead at the instrument cluster connector and tap into that. It is white with pink stripe. It should be on the White connector with 14 pins. (The Connector actually has 16 slots but only 14 pins.) It is the longest of the connectors.
JMC
Old Aug 2, 2007 | 11:53 AM
itimebomb89's Avatar
there is a green wire that comes off all of your ignition coils, splice into one of those.
Old Aug 2, 2007 | 08:14 PM
s1037s's Avatar
I have only two coils, is this info still correct?
