Another Edge Evolution question.....
Old Jul 11, 2007 | 10:01 PM
mattyb777's Avatar
I searched and searched for this but couldnt find it....Sorry if it is a repeat but I have a question for you guys....
I put on my 305/70/18 procomps and my dealer re-calibrated my speedometer and my shift points for me...(actually for free, I didnt even ask him to)
I want to buy an Edge. Reading the manual for the Edge, I read this:
"If you have used another tuner/programmer on your truck, you will need to program your truck back to stock before using the Evolution.
Failure to return to stock may result in PCM failure or engine damage."
BUT, here is my question...So.....does this mean that I would need to take it back to the ford dealer (since he changed the speedo and shift points) and have them put it back to the stock settings before hooking up a programmer????
Any help would be appreciated...
Matt
Old Jul 11, 2007 | 10:09 PM
Kevin24's Avatar
You can use the edge.Basically what that means is you can't put a tuner in your truck and then put the edge in if you have not returned it back to stock on the original programmer you have used (run on sentence!!!)
In short you are good to go as long as you are not using another power programmer!!
Old Jul 11, 2007 | 10:28 PM
mattyb777's Avatar
This might still be a stupid question but isnt what the dealer does the same as programming my truck with an aftermarket programmer?
Old Jul 11, 2007 | 10:32 PM
Tical84's Avatar
The dealer replaces (overwrites) your stock tune so technically speaking you are stock now and don't have to worry about taking it back to the dealer.
Old Jul 11, 2007 | 10:51 PM
mattyb777's Avatar
So let me get this straight. If I add an Edge...then return the truck back to stock, it will go back to what I have now?
Old Jul 11, 2007 | 10:59 PM
ThumperMX113's Avatar
Correct. It saves the current program onto the Edge module.
Old Jul 11, 2007 | 11:16 PM
mattyb777's Avatar
Awesome....Exactly what I needed to hear!!
BTW.....you have the best truck on this site....hands down....
Old Jul 11, 2007 | 11:30 PM
. . you're going to make me blush! Thanks though man.
Old Jul 12, 2007 | 12:44 AM
Foxacrombie's Avatar
I agree.
Old Jul 12, 2007 | 02:10 AM
mgp32's Avatar
The girl aint to bad either!
