Edge Evo ?s
Old May 20, 2007 | 11:33 AM
twintips_17's Avatar
Edge Evo ?s
Im looking at buyinghte edge evo and i see that there is an eef2100 and am eef2000. I know the differance is that the 2100 comes with the monitor. My ? is when you buy the 2100 do you have to use the 2000 to make hte adjustments or does the monitor make all the adjustments? I was just curios as to weathe i had to keep unpluging the monitor to hook up the programer and make adjustments.
Old May 20, 2007 | 11:52 AM
If I understand your question, yes, the monitor has to be plugged up with any program tuner when making changes. How else would you know what your options are or where would you enter what you are wanting to change? Just get the 2100 and follow all directions carefully. Most of us leave the monitor plugged in so we can use the gauges.
Old May 20, 2007 | 11:55 AM
my ? is do i make hte adjustments throught the monitor or throught a seperate tuner
Old May 20, 2007 | 02:52 PM
faawrenchbndr's Avatar
With the 2100 the adjustments are made with the monitor.
