"Tricking the Tuner"
Old May 16, 2007 | 12:19 PM
wasachevyguy's Avatar
I have a Superchips 1714 for my '04 screw. I have 3.55 gears that are a little slow off the line. Is there any way of "tricking the truck" by telling the programmer that I have different gears? Like if I punched in 3.73 or higher would it help matters by reprogramming the engine to have some more grunt? I doubt this is possible but I thought I'd ask anyway. Thanks fellas.
Old May 16, 2007 | 12:23 PM
MGDfan's Avatar
Hi.
Sorry - that won't work. You'll only end up peckering your speedo & tranny shift points.
You could invest in either gears and/or a custom tuner for more grunt.
Good luck
Cheers
Bubba
Old May 16, 2007 | 12:55 PM
Veteran: Army
gears should bring your mileage back up too long with more power in the "S.O.P. meter"
Old May 17, 2007 | 01:58 AM
Would someone mind translating this for me into english? Thanks.
Old May 17, 2007 | 05:31 AM
Hokieron's Avatar
SOP Meter is "Seat Of Pants", You will be able to feel a measurable increase in the grunt factor.
Old May 18, 2007 | 12:52 AM
Zaairman's Avatar
Your *** dyno will register more horsepower.
Old May 18, 2007 | 08:04 PM
Screw-Me-05's Avatar
DITTO........
Old May 20, 2007 | 09:27 AM
TSDan's Avatar
I can't see the reason for the sluggish starts except the tuner and tunes.I have 3:55 in an 06 with a 4.2 v6 auto, Troyer tuned and I smoke the tires (33" B F Goodrich rugged trails).It is great out of the hole,so I would say change tuners and tunes.
Old May 20, 2007 | 10:35 AM
Ftruck05's Avatar
The Edge manual says.
"When drag racing, changing to a higher gear will provide more torque off the line. There are formulas that show the best gears to use based on HP, vehicle weight, as well as other factors. Be aware that when running higher gears your engine will run at higer RPM's and your fuel economy will suffer."
IMO i would say you could tell the tuner that you have 4.56's and it wont do much except empty your tank faster.
Old May 20, 2007 | 11:04 AM
chris1450's Avatar
The edge manual is refering to actually changing the gears in the rear end.. not programing changes. You will gain nothing by telling the computer you have different gears.. in fact it chould wreck the way the truck drives.
Old May 20, 2007 | 02:01 PM
Ftruck05's Avatar
[QUOTE][The edge manual is refering to actually changing the gears in the rear end.. not programing changes. You will gain nothing by telling the computer you have different gears.. in fact it chould wreck the way the truck drives.
/QUOTE]
No, the edge manual is definatly refering to "tricking the truck". If you tell the programmer that you have 4.56's it will make the truck shift like you had 4.56's. I agree it would probly wreck the way the truck drives
Old May 20, 2007 | 02:39 PM
thanks fellas. i guess i won't try that. i guess i'll just have to save up for new gears.
