Weird squeek noise after I instaled edge!Help!
Old Apr 26, 2007 | 06:16 PM
Kevin24's Avatar
Originally Posted by mgp32
I called checker and they have a gatorback in stock! What is the actual name of the belt I should replace? Thanks...
It's a serpentine belt.
Old Apr 26, 2007 | 06:56 PM
mgp32's Avatar
Cool,thanks man...have you changed yours out yet? If so, how did you like it and could a rookie like me put it in?
Old Apr 26, 2007 | 07:08 PM
Kevin24's Avatar
I replaced mine w/ a new belt and still have the squeel.I didn't use a gatorback which i should have.Many others have used them and prob solved.I would try it but am too cheap to buy another one until this one wears outYou should have no prob changing it yourself.Takes about 10-15min,just make sure you have a breaker bar for the tensioner.Pop your hood and you should have a diagram showing where the belt goes.
Old Apr 26, 2007 | 07:20 PM
The gatorback belt cured my Edge belt squeal.
Old Apr 26, 2007 | 08:56 PM
mgp32's Avatar
So with the Edge making all this extra power...actually causing the belt to squeek...will it harm my engine in the long run or the tranny if I put the gatorback it? Im sure it wont but just wanted to know what you guys think. Do you know if they make gatorbacks for different belts...cause I called the guy and asked if he had one for my truck and he said ya...I didnt ask it was for the serpintine belt...but do you think he thought thats the one Im talking about?
Old Apr 26, 2007 | 09:05 PM
The accessory drive belt has nothing to do with your tranny. There are numerous belt sizes available, but only one size for your application. I recommend a search for your exact size..
Old Apr 26, 2007 | 09:45 PM
mgp32's Avatar
I called Checker and they said they had it in stock for my year truck and engine...so I assume it should be the right size. Ill go pick it up tomorrow and let yall know if it solved the problem.
Old Apr 26, 2007 | 11:34 PM
mgp32's Avatar
Oh and just to let you guys know...I ordered the Edge Evo yesterday evening at about 5:30 from Autoanything and got it today before noon!! Thats crazy fast shipping.
Old Apr 27, 2007 | 06:19 AM
openclasspro#11's Avatar
not etra poer- higher shift pressure
Old Apr 27, 2007 | 08:37 AM
chester8420's Avatar
When your transmission shifts REALLY hard, it slows the engine down so fast that the accessories' rotating mass keeps them spinning at the higher speed for a while. That's what causes the belt squeel on the shift. Level 2 on my truck is hell. I can't imagine why anyone would want to run it. I leave mine on level 3. It is just as fast and it doesn't shift as hard. I have had no problems with pinging using 87 octane. I have done this for around 35-40,000 miles. (I'm at 203,000 right now)
Old Apr 27, 2007 | 11:59 PM
mgp32's Avatar
What does "pinging" mean again? Level two isnt too bad...actualy it runs pretty good. I havent tried level 3 but I will try it probably on next fill up. I put about 40 miles on this tank and had WOT a few times and am averging 16 miles mpg on the display with a 50/50 highway city mix.
I got a few questions. What do you guys usualy got for the MAF? I have seen it get up to as high as around 130 when I have gottin on it hard. Also, my ECT is always around 198...is this OK? Sorry for all the questions but just trying to see if everything is in check.
Old Apr 28, 2007 | 12:31 AM
Running lean, detonation.
Old Apr 28, 2007 | 09:34 AM
MGDfan's Avatar
...Or too much ignition advance at a given load for the octane used. It can be incipient and/or transient.
mgp32 - ECT of 198 degrees is fine & normal. Ignore the MAF reading - you can't do anything with it & the units mean nothing to most folks.
Old Apr 28, 2007 | 10:52 AM
Grant54's Avatar
I just replaced my belt yesterday, 4/27, and I don't think the new one is slipping. It definitely isn't squeeling like before, but it may have a slight slip at WOT shift. I might even bump my shift pressure down slightly. I have a Predator programmer. I believe I'm at 70% now. When this belt starts squeeling at shift I'll take it back because of the 2 year warrantee and get this Gatorback ya'll speak of. I wish I would've known about it before. Oh well. This on seems much better and my old one was done anyway. It would squeel at first start of the day if it had rained or really humid for about 10 seconds.
Old Apr 28, 2007 | 11:56 AM
mgp32's Avatar
Good news guys...I just put on the Gatorback and the squeek stopped(or so I thinik so...I only took it for one spin). Thanks again for the guys that mentioned to swap that out...
