Edge High Revs
Old Apr 23, 2007 | 08:56 PM
stucandu's Avatar
Edge High Revs
I got my Edge about a month ago. Not sure if it did this right away, but whenever I start the engine when it's cold it jumps up to quite a high rev, almost 2000, then it settles down fairly quickly to about 12-1300 before it finally drops down to about 800 or so.
Pretty sure it only went up to around 1500 before the Edge.
It may have started doing this after I took it out one day to install the Lightning software, I never updated it though.
Anyway, just curious if anyone else has experienced this and what should be done. I have it set on Level 2 with only the tire size modified.
Old Apr 23, 2007 | 09:07 PM
gilsnuxs's Avatar
MIne does the same thing. I go to work early morning it has always done that. Even before the Edge.
Old Apr 23, 2007 | 11:43 PM
ThumperMX113's Avatar
It's normal.
Old Apr 24, 2007 | 12:21 AM
stucandu's Avatar
ok, it's normal, but is it any good for the engine to go from 0 to 2000 upon ignition when it's cold?
Old Apr 24, 2007 | 11:24 PM
chris1450's Avatar
short answer... yes. It gets the oil flowing faster to the parts that need it most.
Old Apr 24, 2007 | 11:28 PM
Yes. It's pretty much an electronic choke.
Don't worry about it, everything is fine.
Old Apr 25, 2007 | 12:06 AM
stucandu's Avatar
Ok, Thanks, good to know.
