Chalk me up for Edge problems...
Old Apr 5, 2007 | 04:07 PM
FX4 Matt's Avatar
Registered User
Originally Posted by NCSU_05_FX4
Return it, get your money back, call Troyer Performance and get the best tune out there!
- NCSU
X2
Old Apr 5, 2007 | 05:42 PM
Ftruck05's Avatar
I got home from work and disconnected the battery im gonna go recconnect and see what happens now. im thinkin if i reset the ecu it will clear whatever the edge tried to do and i can start over. The truck ran like a raped ape today though, no cel's no misfire.
Old Apr 5, 2007 | 06:55 PM
jes1f150's Avatar
- NCSU
Why didnt I listen to you guys the first time. Edge going back! Had probs last night. Xcal2 from Troyer was orded this afternoon. THE WAIT IS GOING TO SUCK!!!!!
Old Apr 5, 2007 | 07:20 PM
Ftruck05's Avatar
So I test drove my truck and it still felt different. I got home and plugged in the edge...Ignition on not running. The edge says A PREVIOUS PROGRAMMING SESSION HAS FAILED PRESS ANY KEY TO RETURN TO STOCK. So i look for the ANY key I push enter and the evoloution screen comes up and then the gauges pop on.. I go into diagnostics and than version info. This is where it gets F'd up. I push enter after viewing the version info and it says THIS EVOLUTION HAS NOT YET PROGRAMMED A TRUCK. WTF! The box in the upper right says 0. So I try to load lvl2 and again it got all the way to CALCULATING CHECKSUM and came up with a CHECKSUM ERROR RXCM5A6. I am gonna plug my edge into the comp now and try to upload some stuff mabey? It says in the manual they can possibly download a program to the edge to make it work on my truck. Why is the CHECKSUM ERROR the same as my hex code
Old Apr 5, 2007 | 07:45 PM
Ftruck05's Avatar
Here are the newest updates that i can apply
FIRMWARE
Version 2.50.2091-(BETA)
Released on 03/27/2007
*BETA*
Fixed a problem that would give a checksum error even when the files were being read correctly.
CALIBRATION
Version 1.0.2163-(BETA)
Released on 03/29/2007
*BETA*
Fixes an issue in 2007 trucks that would set a P0605 error.
Adds support for the following...
RXDG3F3.HEX
I looked at all of the release updates and my hex code is not in any one of them. Also every time I connect my edge to my computer it says STOCK FILES DONT MATCH DOWNLOAD NEW?. At the bottom right of the lightning software window it says Programmed level 0. It always recognizes my Hex but was somehow programmed to another vehicle? I just DFK
Old Apr 5, 2007 | 08:22 PM
F150Truck'in's Avatar
- NCSU
X3,
Don't feel bad, I had a EDGE to and it had a very short stay in my truck, Call Troyer and your tuner problems will end.....
Old Apr 6, 2007 | 10:16 AM
MGDfan's Avatar
Originally Posted by FX4 Matt
X2
- NCSU
X4. X5. X6
Hey! You guys quit stealing my line - old fart's privilege!
Cheers
bubba
Old Apr 6, 2007 | 03:46 PM
Ftruck05's Avatar
About an hour ago I was talking to tech support and just as I finished explaining my situation the tech says "oh.. it looks like our server just went down, whats a good number to reach you at?" So I gave him my cell and am waiting for his call. The edge still works as a nice gauge setup, I hope they can correct my problem because this is bothering the hell out of me.
Old Apr 6, 2007 | 04:00 PM
JohnRMK's Avatar
Don't give up, I had 2 programmers the 3rd finally worked, and very happy that it finally worked!
I had same thing happen, check sum error on the first unit, than the other would not power up
Regardless I plugged this one in and worked perfect, I am not even going to bother trying any updates, as why?, if it works leave well enough alone, its not like there is going to be an update to gain any more performance, correct me if I am wrong though.
Good Luck, its just that some have more patience than others and I think my patience paid off
Old Apr 6, 2007 | 04:15 PM
Ftruck05's Avatar
Actually I heard that the price went up because the updates are actually going to be useful. Dont quote me on this but I think they are claiming updated programs with 40-80hp gains. That would be sweet
John how long did it take before you got one that worked? Did you call Edge every day? Who covered the postage?
Old Apr 6, 2007 | 04:49 PM
Ftruck05's Avatar
So i just called Edge back and their server is down . The tech I spoke with this time told me straigt up that as of right now my Edge is just a nice set of gauges. The problem I am having has to do with the FIRMWARE. He told me that they thought they fixed this problem with update Version 2.50.2091. They didn't and as of right now they do not know when an update to fix it will be available. He said if I wanted to I could try to return the Edge to Autoanything.com but a new one would most likely have the same problems . I guess i just have to wait it out and keep checking for updates. Man this really sucks. On a higher note i ran an 8.16 0-60 in stock form
Old Apr 6, 2007 | 05:25 PM
PhqChevys's Avatar
Egde has a new update that is suppost to correct that problem...
Firmware: v22
Calibration: v25
Old Apr 6, 2007 | 05:44 PM
Ftruck05's Avatar
Like I said
The update was available 3-27-07 DOES NOT FIX THE CHECKSUM FAILED
Old Apr 6, 2007 | 06:09 PM
MGDfan's Avatar
That would also be dreaming
Just not possible - not in a canned tune, even at the low end your estimate.
And, the price went up due to the enforcement of Edge's MAP policy.
Sorry.
Old Apr 7, 2007 | 12:14 PM
Ftruck05's Avatar
I just opened my lightning software and there was a new update available. version 3.0...I hooked up the edge but their server must be down cause I cant update it. Ill try later.
