which edge 2003 5.4?
Old Mar 30, 2007 | 12:18 AM
masonball's Avatar
I know for the superchips I need the 1715 model, but for the edge, which one should I use?
2003 s/cab 5.4 auto 3.55 ls
and I won't ask which one to get, there's like 1,000 posts about which one is better - I can figure that out. Just don't know which edge to use.
also, does the edge have to be mounted on the dash?
thanks
Old Mar 30, 2007 | 05:49 AM
Kevin24's Avatar
the part ## is EEF2100 and you do not have to mount it.Simply load it and after programing is complete remove from OBD port.Why do you not want it mounted????????
Old Mar 30, 2007 | 06:25 AM
undeaddemon's Avatar
Thumbs up
Yeah man... mount it.... the 4 additional gauges are great..!
Old Mar 30, 2007 | 11:12 AM
masonball's Avatar
It looks awesome and will be fun to use mounted, just seems inviting to poeple looking for a reason to break in. do either of you have that particular edge? how do you like it? also, if I buy it used, is it locked?
thanks
Old Mar 30, 2007 | 12:52 PM
Kevin24's Avatar
thanks
Tint your windows and they won't see I am very happy w/ mine and recomend it.As long as it was returned to stock before you buy it you should be fine.If not i think edge could fix it but not sure on price
Old Apr 2, 2007 | 10:42 PM
masonball's Avatar
I think I really screwed up not buying the edge before the 1st of this month. A $100-$150 increase seems crazy! whats the difference between the eef2000 and the eef2100? other than 150 bucks?
Old Apr 3, 2007 | 02:41 AM
BSL's Avatar
BSL
if you didn't buy an edge by now just go with a custom xcal from troyer, it's now a better deal. when I bought my edge I just wanted a can tune for cheap, but since thats not available anymore, just go custom. You'll get more power and probably be just as happy or happier than having the edge, other than not having guages.
Old Apr 3, 2007 | 03:31 AM
masonball's Avatar
where is troyer located and how much does his work cost?
Old Apr 3, 2007 | 07:34 AM
MGDfan's Avatar
Read --> https://www.f150online.com/forums/sh...d.php?t=280418
For costs, you'll need to contact them - it's the rules here. You do get a discount being a member here ...
Old Apr 3, 2007 | 07:45 AM
05RedFX4's Avatar
The EEF-2000 is the old design, no guage display. The EEF-2100 is the new one based on the eef-2400, has the guage display and 3 preloaded canned tunes.
Old Apr 3, 2007 | 11:14 AM
masonball's Avatar
is it worth buying an edge (probably the 2100 if I buy one) if I'm only going to use the 87 octane? I know the high perf. setting requires 91 or better, but I want to SAVE money on gas, not spend more. Thanks
Old Apr 3, 2007 | 11:33 AM
05RedFX4's Avatar
That's entirely subjective, if your not interested in the guages, then a custom tuned x-cal 2 from Troyer is cheaper.
