Edge guys..this question is for you
Old Mar 29, 2007 | 04:01 PM
James321's Avatar
My edge is here. I have read the manual, cover to cover. Now I have two question that are not addressed in the manual.
1. Will I have any problems with the overdrive; will I have to turn off the overdrive under standard driving conditions?
2. I think I read in a post on this site that the edge tunes can be loaded into the PCM and the edge unit can then be disconnected and removed from the truck. If so, what is the procedure?
Thanks for the help......
Old Mar 29, 2007 | 04:15 PM
The Edge had no effect on my overdrive other than it seemed to lock up a little firmer. Works great
If you don't want the monitor for displaying, you just unplug it from under the dash once it is completely thru programming. You new program is saved to your truck.
Old Mar 29, 2007 | 04:17 PM
RYAN24's Avatar
1......You shouldn't have any problems with your overdrive.
2.....You just set your settings, load, and when its complete just unhook your edge and thats it. Once the screen says LOAD COMPLETED ,your good to just unhook it
Old Mar 29, 2007 | 04:22 PM
beckerjs's Avatar
I think Ryan and Bluejay need to spend some time without each other
Old Mar 29, 2007 | 04:24 PM
Old Mar 29, 2007 | 04:31 PM
beckerjs's Avatar
when I read the 2 post they seemed exactly the same, maybe not, just messing with ya
Old Mar 29, 2007 | 04:39 PM
RYAN24's Avatar
sorry bout that......i was typing mine when bluejay submitted his
Old Mar 29, 2007 | 05:14 PM
James321's Avatar
Thanks to all. Will load up the programs tonight.
Old Mar 29, 2007 | 06:34 PM
SR89racer's Avatar
I just got mine and hooked it up and man what a difference.(level 2 for now) i noticed you can custom tune it! what do you guys have yours set at?
Old Mar 29, 2007 | 08:14 PM
BSL's Avatar
BSL
just ride around with level 2 for a while, once you have a feel for what you want to change then change it, no sense turning your truck into a large lawn ornament just cuz you're excited. not trying to be mean just don't want to see your truck go down cuz you were monkyin' without knowing what you actually wanted. good luck
Old Mar 29, 2007 | 08:15 PM
Dreg's Avatar
What's the proper procedure for plugging the edge back in?
For instance, loaded tune 2, unplug the edge from PCM port while truck is off. What is the proper way to plug it back in? Truck is running, plug in? Or ignition on, plug in, then fire her up?
Just wondering.
Old Mar 29, 2007 | 09:02 PM
MGDfan's Avatar
Just wondering.
Hi.
Answer: http://www.bitschubser.com/HowToRTFM...0-%20HOWTO.htm
Hint - it's in the "getting connected' section - I just checked :-))
Survey:
Does this response answer your questions?
[] Yes.
[] No.
[] WTF ???
[] Go pound salt.
J/K ! LOL! Welcome!
Old Mar 29, 2007 | 09:36 PM
87 octane:
shift RPMs: 1-2=5250 2-3=5250 3-4=4800
Max RPMS: 5600
speed: 110
Shift pressure: +12 on all shifts
normal shifts: no change
timing: no change on level 2 running 87
WOT Fuel: +1.5
I run the same setting for level 3 with 93 octane except I bump the timing +1.5
Old Mar 30, 2007 | 11:44 AM
chester8420's Avatar
The edge doesn't care how or when you plug it in. It makes NO difference whatsoever. It can be running, off, on accesory, dead battery, upside down, it doesn't matter.
Old Mar 30, 2007 | 01:44 PM
SR89racer's Avatar
according to the paper in my edge box it states to make sure the key is on before you plug the edge in to the truck!
