Edge Speedo Correction Problems
Old Mar 22, 2007 | 10:19 PM
rrch129's Avatar
Ive had my edge since Christmas time and love it...the only thing is my speedo is still of in my 2004 fx4 with 3.73 ls and 35 in pro comp a/t's...i used the recommended mm measurement and then measured and either way its 5 mph off i dont kno wat to do????
Old Mar 22, 2007 | 10:35 PM
RYAN24's Avatar
Well the edge is probably closer to being right, not your factory speedo.
Old Mar 23, 2007 | 09:45 AM
expy03's Avatar
These trucks have a built in 2-4 mph error from the factory. Don't know why.
If you used the rolling method and got a good reading on the tires and the proper mm to plug into the formula, then check your odometer. It shoud be right on. Your speedometer will be off 2-3 mph still.
So it the odometer is right on, then your EDGE settings are good. It's just the Ford speedometer. What I did is go with the bigger tires on my work truck and it caused the speedometer to be right on, but the odometer is reading slow.
Do you have a GPS to compare speed?
Old Mar 23, 2007 | 09:47 AM
I checked my Edge with a GPS. My factory speedometer was 4 mph fast while my Edge was 2 mph fast.
Old Mar 23, 2007 | 09:56 AM
expy03's Avatar
About the same for me. Bill from EDGE stated in a post from back when we first got these things that basically you could have an accurate speedometer or an accurate odometer with these trucks. Not both.
I prefer to have a slightly slower odometer.
Old Mar 23, 2007 | 12:58 PM
Keith460's Avatar
Originally Posted by Keith460
I would go by the reading you are getting with the GPS because you can still adjust the Edge to match that speed. I think all Ford truck speedometers are always off by some and mine is no exception. Edge indicates 60 mph, speedometer is 61 or 62.
However, my Edge is programmed correctly as it was tested against the readings of a GPS. You can do the same by lowering your input number slightly to get you speedometer and Edge to clock slower. Lets say you programmed a number around 2660 for the tire diameter, lower that number by small increments to around 2655, 2657, etc. and then check with a GPS and mile markers on a highway for at least 10 miles. This will be a trial-and-error procedure and takes awhile to achieve correctly.
Same problem different post
Old Mar 23, 2007 | 01:35 PM
sysman_rick's Avatar
Post
Edge manual states 1-3 mph error.
Old Mar 23, 2007 | 02:52 PM
DracoF150's Avatar
So you guys would say the EDGE is more accurate correct???
Old Mar 23, 2007 | 10:24 PM
bshipley78's Avatar
Yes, I called Edge tech Support today and asked them about it because it has been doing it on my truck as well, and the guy at Edge said that the Edge tuner reads directly from the PCM so it is the most correct speed.
Anyone else get a ghost in their truck after installing the Edge, since I have installed mine I have had all kinds of weird quirks going on, like my radio just shutting off out of the blue and the wipers and windows have been intermittently working. The guy at Edge said it probably isn't the edge module, but I think it may be since I just put it in a couple of days ago and now all of the sudden these things are happening.
Old Mar 23, 2007 | 10:51 PM
expy03's Avatar
I have a 2005 Supercrew and have one of the first EDGE units sold. No problems.
I did notice that on occasion I activate the wipers when using the turnsignal.
But that's it. No problems like you describe.
Old Mar 25, 2007 | 12:00 PM
chris1450's Avatar
as far as speedo being off, the government allowence is 4mph max. the japanese companies are being sued right now because they proved that they did it to the electronic speedo... so that miles racked up quicker.. so they go out of warantee faster. the electronic speedo on our vehicles should be right on. The one you read is most likely off. On the lariat modles there is a way to access the computer mph on the display screen... do that and compare with the regular speedo.
