Edge Level 2 or 3 On HWY ?
Old Feb 19, 2007 | 08:15 PM
Originally Posted by PB06FX4SCREW
Is it ok to change from level 2 to level 3 while driving? Say level 2 around town then switch to 3 when getting on the freeway.
PB
No. Must be key on engine off to change tunes.
Old Feb 19, 2007 | 09:50 PM
josho66's Avatar
Originally Posted by Stealth
Level 3 is a 91 octane tune, but you can adjust the timing for the 93 octane fuel. You can run 93 in level 2 as well, just adjust the timing. The amount of timing to add for each ocatne is listed in the manual.
Sounds good. I will just run the 91 octane then, it is much easier to find. The 93 is very hard to find around me. thanks.
Old Feb 19, 2007 | 10:00 PM
chester8420's Avatar
PB
Ya'll REALLY need to read up on tuners. With questions like this, you obviously don't know a lot about tuners. I'm not trying to make fun of you, I just don't want you to break your truck. This thread goes over the basic functions of tuners. Make sure you understand it, before you start using the tuner. https://www.f150online.com/forums/sh...d.php?t=273030
Good luck with the edge. You'll like it.
Old Feb 19, 2007 | 10:30 PM
josho66's Avatar
Just read through it, very informative. I was just curious about ethanol and couldn't remember if the Edge needed 91 or 93. I have had a tuner before. I will agree 100% with everything you said. I think the key point is just follow the instructions and you should be ok.
Old Feb 20, 2007 | 09:36 AM
Exactly, follow the instructions, the majority of problems are user error. As far as ethanol is concerned, pay close attention, listen to your engine. You can even get pinging (pre detonation) with the stock program. If you are running a tuner program, you can back off the timing, but if on stock, I would go to the next grade of gasoline.
