Thinking About A Tuner? - Read This First
Old Mar 8, 2007 | 11:05 AM
  #31
PearlandAl's Avatar
My edge should be in today and I was wonderng what is the best level to run it on for a 2006 4.6L F-150 Fx4 Screw? And it I run level 3 what are some custom tunes you guys with the same truck might have? Thanks for all your help!
Old Mar 8, 2007 | 12:19 PM
  #32
sysman_rick's Avatar
Thumbs up
Execellent explanation....... definitely needs a stickey.
Old Mar 12, 2007 | 10:05 PM
  #33
chester8420's Avatar
Originally Posted by Gotts2BMe
You shouldn't have to go right to the dealer to get the paint matched you should be able to go to any aftermarket paint place to get it for about 1/2 the price. I have never had an issue with the paint being off at all. Just tell them your paint code and ask for a spray can or bottle with the brush
You can get a spray paint can from the dealer for around $20, maybe less (I can't remember). That's pricey as far as paint goes, but cheap since it is an exact match...
Old Mar 28, 2007 | 04:44 PM
  #34
flareside4life's Avatar
bump, good info. Webmaster, since this isn't a sticky could you please explain why it is not "sticky" material?
Old Mar 28, 2007 | 04:48 PM
  #35
undeaddemon's Avatar
Exclamation Can we PLEASE make this a STICKY??
Old Mar 28, 2007 | 05:41 PM
  #36
NASSTY's Avatar
[QUOTEchester8420]You can get a spray paint can from the dealer for around $20, maybe less (I can't remember). That's pricey as far as paint goes, but cheap since it is an exact match...[/QUOTE]
I'm not sure if it was posted somewhere and I missed it or not but I'll post it anyway.The Ford part# for the dark flint grey paint is # PM-19M547-2002H
Old Mar 28, 2007 | 06:09 PM
  #37
Net Wurker's Avatar
Is dark flint grey the color in the Lariats with tan/grey dashboards?
Old Mar 28, 2007 | 08:21 PM
  #38
NASSTY's Avatar
I'm not sure the last few lariats I looked at had the silver trim. My XLT has light grey w/ dark grey interior and dark flint grey matches the dark grey trim in my XLT.
Old Mar 28, 2007 | 08:37 PM
  #39
Net Wurker's Avatar
Silver - grey...I can't tell the difference. I guess I'm color blind....thanks for the nfo, though.
Old Apr 7, 2007 | 04:13 PM
  #40
BSL's Avatar
BSL
Question Why not a Sticky?
The constant posts about wondering if you need to return to stock show that THIS NEEDS TO BE A STICKY. Thanks chester this helped me out a lot before I purchased my tuner.
Old Apr 8, 2007 | 10:42 AM
  #41
aftermarket's Avatar
Ok, from reading the first few posts, I have a question about the cold temperature part of the articles.
So you're saying don't use the programmer when it's cold out, or don't use the truck with anything other than the factory tune in cold weather?
Just want to clarify that before I ask more dumb questions...LOL..
Old Apr 8, 2007 | 11:24 AM
  #42
Ftruck05's Avatar
When it is really cold out 20f or lower the edge may lock up during the inital start up. This is because the edge requires something like 12.2v to boot up and your battery doesnt have all that juice to give when its trying to start your cold *** motor. This has happend a couple of times to people i know and it has not been a big deal, just unplug and replug to the OBD. You should not attempt to install the edge in severe cold because the first time you install it your stock program is written to the edge and if that process is interrupted you are in trouble. The Edge is not some fancy *** computer. If you know what you are doing than you should not have a problem. Also the edge for the 04-07 has only been out for 3 years, so I personally do not think that is enough time to work all the bugs out. My truck is an 05 and i got the edge last week only to learn it is a nice set of gauges, I cant program any level. Edge is having a problem with the Checksum files and i have to wait untill they come out with an update. WTF
Old Apr 8, 2007 | 12:00 PM
  #43
MosineeFX4's Avatar
Actually, the Edge programmer for the F150 has been out less then 1-1/2 years. I was one of the first ones to get one (Jan. 06) and I have been running mine since. I would agree not to try to install or program a different level during extreme cold periods, but I see nothing wrong with using the Edge during any temperature. I have ran mine constantly through all kinds of temps without problems and it can get awfull cold up here in WI.
Old Apr 8, 2007 | 03:19 PM
  #44
MGDfan's Avatar
Hi Aftermarket -
Here's a good thread that provides some more detail on the cold weather issue:
https://www.f150online.com/forums/sh...ight=flash+nvm
Cheers
Bubba
Old Apr 24, 2007 | 07:58 PM
  #45
I edited the post to clarify it a little... All it is saying is, just don't tune the truck while it's VERY cold. The computer's memory reacts differently at lower temperatures and there is a higher chance for "errors" when the weather is cold. You can use all the other functions of a tuner normally, but just don't change the tune. Unless you warm the truck up first...
