Edge Evo level 2 problem
Old Nov 19, 2006 | 09:07 PM
Joe_STX's Avatar
When I program my truck to level 2, I get some engine knock when the truck is under a strain such as going up an incline. When I return it to stock, the engine knock goes away. Anyone else have this problem?
Old Nov 19, 2006 | 09:15 PM
built54's Avatar
what octane fuel are you running? Sounds like detonation
Old Nov 19, 2006 | 09:19 PM
Nope. The only time I had a knock was on level 3 with some Exxon 93. Went back to Shell, no knock.
I do have a new problem though. I returned to stock for a week or so, took truck in for service. Oil change, rotation and state emissions inspection. When I got home and tried to go back to a custom level 3, I got the message that my unit did not support my current calibration. Now what did they do to my computer? I will have to upgrade my Edge, just have not had time to mess with it.
Old Nov 19, 2006 | 11:04 PM
expy03's Avatar
The dealer may have updated your stock calibration. Hopefully EDGE can help when you get time.
I get just a minor knock at part throttle on some days. It does the same thing on my 05 worktruck with a stock 5.4. It's minor so I haven't worried about it much. May just be the fuel I use sometimes.
Old Nov 20, 2006 | 06:59 AM
Joe_STX's Avatar
You are suppose to be able to run 87 octane with level 2. That's what I am running.
Old Nov 20, 2006 | 08:28 AM
FX4_Guy's Avatar
I got that error once or twice before. I just unplugged the EVO and plugged it back in and it didn't have any problems after that. I can't remember if I unlplugged it and plugged it back in while the key was turned to on or not.
Old Nov 20, 2006 | 09:14 AM
OK, I will go give that a try. Thanks.
Old Nov 20, 2006 | 09:53 AM
Ok. I unplugged it and followed their steps for plugging back up, works fine now. And the calibration was different from the original. FX4_Guy, Thanks for the advice.
Old Nov 20, 2006 | 11:39 AM
FX4_Guy's Avatar
No problem. Glad I could help out.
Old Nov 20, 2006 | 03:51 PM
C-17 Pilot's Avatar
Joe,
Based on my experience, this is almost definitely a fuel quality problem. The quality of fuel in my area is terrible, and I'd been experiencing a moderate level of engine pinging when under load (e.g., accelerating or going up a hill) for the last several months. I'd even asked the dealer to check it out with no results.
I tried every brand of fuel in my area within a reasonable driving distance, but none of them made any difference. However, one day I happened to be next to a Shell station when my low fuel light came on, so I put ~5 gallons in the tank. Within 15 miles, 70% of the engine pinging was gone. 400 miles later (and nothing but Shell gas), the engine pinging is almost completely eliminated.
The only problem now is I have to drive 10 miles just to get decent fuel for my truck, and Shell gas costs ~$0.20/gallon more here :o ....but it's worth it!
BTW, I'm not saying you need to use Shell gas--I'm just saying this is what worked for me. You should try different brands in your area to see what works best for you.
Good luck!
Old Nov 20, 2006 | 03:58 PM
As mentioned earlier, I have had better mileage out of Shell and Conoco.
Old Nov 20, 2006 | 06:13 PM
FX4_Guy's Avatar
I went to Valero (for the first time) the other day and my truck pings like a S.O.B. I usually put in Shell or Murphy (Walmart) gas and have never pinged. The brand of gas and quality of gas does play a major roll.
Old Nov 20, 2006 | 06:59 PM
00Ford4X4's Avatar
I guess I am lucky. I have at least 20 gas stations within a 5 miles radius of my house...
Old Nov 21, 2006 | 05:08 PM
TXallstar's Avatar
From my experience Shell has had the best gas and in my area the cheapest gas. However, I've never had knocking from Valero either which is where i normally go. I think it mostly depends on your area than the actual brand of gas you get. Also remember that gas goes bad so that could be a factor if the gas station has old gas.
Old Nov 21, 2006 | 07:06 PM
GB150's Avatar
Did you change the timing when you programmed level 2? Level 2 says to use at least 89 octane. You should only use 87 if you adjust the timing.
