Best spark plug for my engine.
Old Oct 23, 2006 | 11:21 PM
built54's Avatar
All my mods are in my signature, I have 1 heat range colder plug in my engine now, but I do no recall what type of plug I put in, I want to replace them soon though because its not running and idling as good as it has. No concern, just maintenance. What do you recommend?
Old Oct 24, 2006 | 08:31 AM
MGDfan's Avatar
Hi. Hands down, Denso Iridium:
http://www.troyerperformance.com/cgi...catalogno=IT20
Denso's site:
http://www.densoiridium.com/index.php
With your mods a colder heat range than the standard IT-16 may be in order. Ask Mike.
Cheers
Bubba
Old Oct 25, 2006 | 06:54 AM
built54's Avatar
Ok I will wait for Mikes responce. Thanks though, I didnt know he sold plugs!
Old Oct 30, 2006 | 04:23 PM
Former Sponsor
Hi Built54,
I agree, go with the Densos - now normally the stock heat range would call for an IT-16, but you have added enough power to drop it down 1 heat range, so use the IT-20's - they are the same price, so no difference there, this is strictly a matter of the appropriate heat range, and that would be 1 heat range colder than stock - so Denso IT-20's it is.
Old Oct 30, 2006 | 11:11 PM
openclasspro#11's Avatar
mikey
Originally Posted by Superchips_Distributor
Hi Built54,
mikey i plan on doing the aef intake-i'm nearing 30k gonna do o2's and plugs- should i go it15t's or 20's since my van is so heavy and i work it?- thanks-phil
Old Nov 1, 2006 | 02:35 PM
Former Sponsor
Hi Phil,
Good question - by the books, Denso calls for an IT16 for your engine - however, the Denso's firing tip burns pretty hot, probably hot enough that you could use an IT20 if you like.
It really gets down to a matter of idle quality, like always - one step too cold on a plug gets you some mild idle misfire.
In your case, it's probably a bit easier to change plugs since you can just yank the cowl cover off and the motor is right there if you wanted to change back to a IT16 if you didn't like the idle quality.
I think you could probably go with the IT-20's and be fine, it's not a bad idea given the EGT's that engine sees - your EGT's, I'm guessing, are probably going to run in the neighborhood of 50-100 degrees higher across the board compared to the average F-150, and that thing doesn't have quite as much in the way of air circulation under the hood like the trucks do, either - so the IT 20's will probably work just fine in your case.
Lord knows it's a heavy pig that gets leaned on, and we'll never take down our picture of that thing on the dyno here.
Old Nov 5, 2006 | 10:50 PM
built54's Avatar
Ok, Im going to go with the IT20's. Would I benefit any from better coil packs?
Old Nov 6, 2006 | 10:29 PM
built54's Avatar
Im ordering them from you mike, should i gap at 34?
Old Nov 9, 2006 | 08:18 PM
built54's Avatar
Well I got them today, It didnt register with me untill i got them today... $10 a plug!!! wow these things must be good lol! still would like to know the gap... im thinking 34
Old Nov 10, 2006 | 08:44 AM
MGDfan's Avatar
Hey Built;
According to Denso, the gap should be 0.050, non-boosted application.
Here's the gapping tips:
http://www.densoiridium.com/installationguide.php
Also , elsewhere on the site are the gap specs - use the product finder to select your truck ...
Cheers
Bubba
Old Nov 12, 2006 | 10:25 PM
built54's Avatar
Thanks, but I think the gap is smaller for 10.5/1 compression... could be wrong
Old Nov 12, 2006 | 11:39 PM
Neal's Avatar
HI!... I'm running the AUTOLITE AR-93's. They are two heat ranges colder than stock. I had the DENSO's and hated them. Wore out just as quick and 4 times the money. AR's are like $25(CAN).
Old Nov 13, 2006 | 05:12 PM
Former Sponsor
Actually, we have found the Denso's to be a far superior plug to the Autolite AR series - they fire hotter, quicker, require far less voltage to fire, and are better in every way - unless you are spraying nitrous, in which case the Autolite AR series makes for a *great* copper-based plug - otherwise, the Denso's are fine, and will easily last 50K miles or more - we've done that many times on our customer's vehicles.
Also, for Built54 - the gap recommendation on the Denso's really doens't need to change just because you have 1 point higher compression, stick with the stock gap is what I recommend - and good luck!
Old Nov 13, 2006 | 11:20 PM
built54's Avatar
Wow... I thought I recall you telling me one time to do a gap in the mid 30's ? denso says to gap at 50
Old Nov 14, 2006 | 12:06 AM
ws6_guyscrew's Avatar
i'm running NGK
