edge capabilities
Old Oct 18, 2006 | 01:20 AM
caseyg's Avatar
Question edge capabilities
i'm looking to put on a cold air intake and high flow exhaust. i have a 2000 f-150 with a 4.6. i've read that the truck will run lean and lose horsepower instead of gaining horsepower. I've been looking to get the edge because i like the guages but i don't know if i will be able to fix this problem with it. If not i will have to go with something different.
Old Oct 18, 2006 | 09:51 AM
There is no programming capability in the Edge for air flow. If you are increasing airflow, I would go with a custom tune from Troyer and his Xcal2. If you are staying stock, or going to an air system that is not any larger, the Edge should be fine. I run the Edge on my5.4 and am very happy with it.
Old Oct 18, 2006 | 10:58 AM
mkinttrim's Avatar
I have NO problem with my Volant.
Old Oct 18, 2006 | 11:01 AM
Silverfish's Avatar
Mike sells the Edge so it can't be all that bad.
Old Oct 18, 2006 | 11:17 AM
NASTY-FX4's Avatar
Ditto
Old Oct 18, 2006 | 04:18 PM
2001Screw4x4's Avatar
The Edge will work fine with a CAI. Don't worry about it, especially with the 97-03 trucks. It was the later models that had the problem with running lean.
Old Oct 18, 2006 | 04:20 PM
It seems to me that the problem came mostly from running the 3.25 AF1. I think Mike Troyer has stated that you need custom programming to run that one.
