Edge disapointment 97-03 Evo
Old Oct 13, 2006 | 10:20 PM
  #31
fs_ar's Avatar
Originally Posted by Etech04
so did you crunch the mileage numbers by hand to verify? that would be impressive.
No I did not. Need to though. I had a family death and then had my new Autometer instrument cluster, Gaugeworks Steering Pod, and Transmission Temp gauge installed. Got everything but the plumbing for the Trans gauge done.
Something looks wrong above. How do you spell "Gauge"?
Steve
Old Oct 14, 2006 | 01:11 AM
  #32
2001Screw4x4's Avatar
Originally Posted by fs_ar
My boys got back from Hallett this evening and was telling me about the new Edge and what they thought about it. They have towed before with my truck and always got in the 8 to 10 MPG range. That was figuring by hand. The Edge said they got 13.5 this trip. To me (if this is a true reading) that is VERY impressive. This is running a out of the box #2 tune.
One thing that did worry them was the shifting. I had noticed that it was quite a bit firmer before without towing, but they said it was snapping their heads with the car behind them. Also they said they thought they heard a small squeal each time from the trans. Should I be worried?
Steve
I tow often with mine, about a 6K lb load. The shifts are fine. The only time my shifts are neck-snapping firm is when I mash the gas and let it shift at 5K rpm. If they are doing that when they tow, they need to learn to drive.
Old Oct 14, 2006 | 02:08 AM
  #33
ozzeran's Avatar
F!!!! THE EDGE
I wasted 379 F'ing dollars on that trash. Pickup was slower, detonated left and right (even with 93 octane)
Now I have to try and return the pos to the ebay seller
As for there tech support........................well they cant support ****. Its ridiculous.
But oh well, I was a sucker and wasted the money.
Old Oct 15, 2006 | 12:43 PM
  #34
Originally Posted by ozzeran
F!!!! THE EDGE
I have seen some of your other posts - running crappy 87 octane - can't get your Outlaw intake installed correctly - maybe you have other issues that are not related to the tuner?
Old Oct 15, 2006 | 01:07 PM
  #35
ozzeran's Avatar
Nope. Its called modding these newer cars. I have had bad luck with them. Everyone praises OMG this truck is so much faster, OMG this truck SOUNDS so much better. They are full of crap and i'm tired of reading pointless posts regarding it. And since when is it appropriate to run 93 octane in a truck that came standard with 230 hp? HAHA. You guys waste so much money on these trucks, just leave them alone and use them for what they were designed for. If it was a Lightning it would be a different story, but c'mon.
Old Oct 15, 2006 | 02:29 PM
  #36
Bluegrass's Avatar
Your absolutley correct.
Leave them alone, don't waist your money.
They are beyond you ability.
Old Oct 17, 2006 | 06:32 PM
  #37
Running 93 on a stock truck is pointless. It is appropriate to run 93 when you have a custom tune designed for it. I do use mine as it was intended - hauling and towing. The Edge gave me a nice power gain when using my truck as intended.
