Edge Confusion/ Performance ?
Old Aug 24, 2006 | 05:41 PM
Gman SC's Avatar
I have had my edge for about 2 weeks now and really like the unit. When I installed it I went to level 2 and really felt a difference in the shifting but really could not tell any seat slamming performance.
Today I had my truck serviced so I reset to stock and removed the unit. I have traveled app.200 miles today and the truck doesn't feel any weaker without the Edge, am I expecting to much? This is not a negative Edge post I am just looking for what to expect and what to look for if I am not getting a good tune.
Should it be very noticeable or just the shifting and a little more pep?
Old Aug 24, 2006 | 07:54 PM
thetruck's Avatar
Did you customize the level you were running or use the stock level 2 tune?
Old Aug 24, 2006 | 08:17 PM
Gman SC's Avatar
Stock level 2 tune. I have not tried to customize yet.
Old Aug 25, 2006 | 10:34 AM
Stock level 2 was not too much better than my stock Ford program. Customized level 3 is a whole different story. i have not tried custom level 2 yet, as i am having too much fun with level 3.
Old Aug 25, 2006 | 02:14 PM
thetruck's Avatar
AGREED!!
Old Aug 25, 2006 | 09:56 PM
Gman SC's Avatar
Can you guys give me some idea as how you set your customized tune on level 3? Also if you set a custom tune and then remove the unit for service or go to a lesser level {ie} towing will the unit hold the custom tune or do you have to redo it.
Thanks,Gary
Old Aug 26, 2006 | 12:57 AM
hmfic's Avatar
I have noticed a huge difference between stock and level 2. The reason you don't see a huge difference is because you just reset your computer. Everytime I set mine back to stock I thought to myself that I didn't feel much of a difference, but after a couple hundred miles it fades, bad...
Old Aug 26, 2006 | 12:12 PM
Gman SC's Avatar
hmfic, what do you mean it fades? Is this to say that when you first go to level 2 you can notice it but it goes away after several hundred miles?
Old Aug 26, 2006 | 01:25 PM
hmfic's Avatar
Sorry, I mean that when you go back to stock (no edge) that the computer is blank after you reset the computer, and that it takes a few hundred miles to "learn" to your driving. Unless you always drive it hard, the performance will fade. With the edge, the performance will not fade.
Old Aug 26, 2006 | 08:12 PM
lew673's Avatar
The computer will store all the driving perameters. If you change something like aie intake or chip etc. Disconnect the battery for a few minutes then reconnect and start the vehicle and let it idle for a few minutes. It will then read the new setting and make the adjustments. This will save you having to drive for miles to readjust the pcm.
