Edge Evo 2 cable to short
Old Aug 14, 2006 | 07:03 PM
Padron's Avatar
Thanks Z,
I wish I had the removable side panel on my truck like the new ones do.
Old Aug 16, 2006 | 03:23 AM
2001Screw4x4's Avatar
Originally Posted by Padron
Hi,
In the manual it does call for the cable to be tucked in under the door seal which make the cable too short.
Hi,
I just got the Edge for my F150 and have a lot of extra cable. I think you read that part of the manual incorrectly. You pull out the door seal so that you can slip the cable behind the dash. The cable does not go behind the seal. If you are trying to keep it behind the seal, I can see why it would be too short for you.
Old Aug 16, 2006 | 02:22 PM
Padron's Avatar
Thanks!!
Old Aug 22, 2006 | 03:33 AM
How did that work out for you?
Old Aug 22, 2006 | 11:22 PM
Padron's Avatar
Originally Posted by 2001Screw4x4
Hi,
Thanks 2001Screw,
Oop's I forgot about this post. I was able to pull off the door seal trim and route the cable a little better behind the dash than I was doing it before.
Now, I have about 3-4 inches of cable which is enough for me to be able to unplug the unit without pulling off the pod.
Thanks again for pointing that out , I guess I was just in a hurry and didn't route the cable correctly.
