Xcal2 and Airforce 1 Question
Old Aug 11, 2006 | 12:15 PM
nineback's Avatar
Mine looks similar. On yours the rubber piece goes along the top and side of the heat shield. On mine I the rubber piece was only long enough to cover the top of the shield. Mine came with a foam strip as well that the instructions say you might want to put in the bottom of the heat shield. The foam strip is just a piece of foam with no adhesive or anything. I thought it might go around the opening where the tube passes through the heat shield but again there is no way to secure it.
Tom
Originally Posted by jpdadeo
Here’s a pic of mine, but remember this was one of the original ones back when the very first came out, so I wouldn't be surprised if it's changed since then
