Need Turner to adjust speedo, and Power and shift points
Old Jul 11, 2006 | 10:29 PM
Night5talker's Avatar
Hello I am looking tor a turner for my 1997 Expedition, with 5.4
I have talked to a couple of companies and found out that they will not adjust my speedo for my 39.5 tires and some will only tune for Super unleaded.
I want it to fix my speedo as well as toon for performance,
Thanks...
Old Jul 12, 2006 | 01:31 AM
Brian 5.4's Avatar
A superchips Max Microtuner (part number 1715 for our trucks) can adjust your speedo and offers a tune for 87 octane fuel, as well as two additional tunes for premium. All three tunes have improved trans shifting. I just bought one and am very pleased so far.
Old Jul 12, 2006 | 10:00 AM
jpdadeo's Avatar
Give TP a call he can fix you up with exactly what you’re looking for via custom tuning
Old Jul 12, 2006 | 02:49 PM
Bartak1's Avatar
None of the tuners out there can adjust for your new tire size, they can only do that on the 99 and up trucks I believe. For the 98 on down years you have to switch out a gear for your VSS. Just a heads up Unless the Expy is different than the trucks.......
Old Jul 12, 2006 | 04:12 PM
ammoeater's Avatar
I do believe Bartak1 is right...
Old Jul 12, 2006 | 04:20 PM
surfnturffx4's Avatar
Your going to have to purchase a Fabtech "truespeed" tire calibrator. You can get one at www.ntwonline.com. I understand just like they stated above that 98 and older fords the tunner will not effect your speedo.
Old Jul 13, 2006 | 01:32 PM
Former Sponsor
Hi night,
No tuner can fix your vehicle's speedo calibration because it's not controlled in the PCM until the 1999 model year for the half-ton F-series platform like you have - and don't feel bad, the Crown Vics & Grand Marquis' didn't get that until 2004! .
However, it's very simple to do - all you need to do is to change the speedo gear in the tailshaft of the transmission, just like speedometers have been calibrated for decades - so any speedo shop can handle that for you, or if you do the math correctly, you can simply order the gear you need from Ford for $20 or less and fix it yourself.
Last - you could also have us provide you with the Truspeed calibrator, which goes inline and can also fix that for you electronically.
Old Jul 14, 2006 | 02:54 PM
Originally Posted by Superchips_Distributor
Hi night,
Ok thanks alot. and a big thanks to all of you guys for your help...
