Just bought my Edge!
Guest
Posts: n/a
Originally Posted by Big D
I have a 2003 screw 5.4 fx4 and i need some performance badly but i am very uncertain what tuner to buy. i am set on a magnaflow cat back but still undecided on the tuner. which edge is this that we are talking about and what kind of performance gains and gas mileage increase can i expect from the 5.4?
Well it finally arrived today.
Installation took all of about 10 minutes, the truck started no problem. The first thing I noticed is that it idles slower than stock. The throttle certainly seems more responsive on LV2 with a tank of 89 octane but I am not sure that I notice a bunch more power. The gauge displays are the best part in my opinion so far. I understand that I may notice a bigger gain as days go on so I will reserve final judgement but I am impressed so far.
The only other thing I need to decide is if I want to put my K&N drop in back. Not sure right now, I want to see if my ping improves with the Edge installed.
Ok, little update. I decided to update the unit with the latest tunes. Level 2 = WOW! This is what I was expecting, more power for sure, great throttle response and better shifting. Now it feels like money well spent.
Originally Posted by beckerjs
does your AMPG work right, every time I let off the gas my IMPG goes to 30 and throws off my average
Originally Posted by candrusiak
Quick question for everyone else, I am running level 2 with 89 octane fuel. Can I advance the timing slightly? Or would it be safer for the truck to leave it as is?
Be aware that baseline octane for Level 3 is 91, though, so you'd need 93+ octane in your tank before advancing the timing.
Originally Posted by C-17 Pilot
For every two points of octane over the tune octane baseline, you should be able to advance the timing by +1. In this case, Level 2 is designed for 87 octane, so you should be able to advance the timing +1.
