First 0-60 after Edge..
Old May 29, 2006 | 09:55 AM
yankeesfan81's Avatar
I have yet to do a 0-60 run with stock settings.. I will do that shortly.. Bu tI did do my first 0-60 run after the Edge on Level 2 with pretty much a full tank.. And i started off with turning slightly to get on the road with moderate acceleration so that I wouldnt spin the tires in the beginning..
But my first number was 10.5s
my truck has no other preformance mods.. I havent installed my volant yet but hopefully I will soon..
Anyone else with the Edge please post your best 0-60
Old May 29, 2006 | 10:19 AM
Blackford's Avatar
im curious what is your 1/4 time?
Old May 29, 2006 | 01:14 PM
bushtree's Avatar
It might just be how you eased onto it and turn in the beginning. but that sounds more like a stock 0-60 time not a post-edge time. Also check your tire size in the edge it might be wrong causing that time to show.
I run a 8.5-8.6 0-60 with my truck.. Its lifted on 35"s and weighs in at 6400lbs.
Old May 29, 2006 | 01:40 PM
FX4 Matt's Avatar
Registered User
I would also like to see some "real track" EDGE 1/4 mile times
Old May 29, 2006 | 11:20 PM
Yeah I will do that the next time I go out to my parents.. There are some nice straight aways that will work nicely...
Old May 30, 2006 | 09:16 AM
05supercrew's Avatar
I have a 05 screw and pulled off a 8.7 0-60 on lvl2. No mods.
Old Jun 7, 2006 | 01:12 AM
valenrandy's Avatar
Well it depends on the weather...
@40' I average 7.2-7.3
@60' I get around 7.4-7.5
@80' I get 7.6-7.7
Its all in the air temp.
high 7s with hi 90's
05 screw 2wd 3.55 non ls
Old Jun 8, 2006 | 03:50 PM
Cypress700's Avatar
Right now my 05 4x4 is running 8.7 o-60,What is strange is originally it was running in the mid 7 range.Level 3 with 93 octane.The only things that have changed are air temps and the updates.Can air temps make that large of a difference??
Old Jun 9, 2006 | 08:19 AM
CJ-F150's Avatar
I just installed my edge last night. I did a 0-60 on level 3 and got 9.8. I wasn't real impressed with that. I changed the tune to level 2 and got 9.59 about 30 minutes later. The temp was about 85 during all this. This morning I returned to stock and got 8.58 for my 0-60. The temp was about 15° cooler, but I expected a lot more from the level three program.
Old Jun 9, 2006 | 08:53 AM
Temp. has a lot to do with it. Dont forget fuel has changed also which doesnt help anything. My 8.7 run was a 50* day.
chester8420's Avatar
0-60 times vary so much from f-150 to F-150, and day to day. There's a lot of variables that contribute to a large range of 0-60 times. Ya'll have to remember, Ford didn't design these trucks to be dragsters. They were designed to give longevity, and versatility, while maintaining reasonable () fuel efficiency.
Old Jun 9, 2006 | 09:22 AM
CJ-F150's Avatar
I was just really dissapointed in my stock tune time beating out the level 3 tune by more than 12%. Hopefully my K&N cold air intake will come in early next week and I can try a run early in the morning on level three.
Old Jun 9, 2006 | 10:44 AM
At what RPM does your truck shift gears?
Old Jun 9, 2006 | 11:05 AM
CJ-F150's Avatar
It seems like it was around 4200-4600 this morning, but I'm not sure of that. I was watching the speedometer and time. I'll have to check that. I really feel like it was probably the air temperature that made the difference. I am going to try again tomorrow morning with level three and see if I can beat 8.59. I'll probably play with it this weekend and pay closer attention to RPM.
Old Jun 10, 2006 | 11:37 PM
On Edge Level 2
Well I did a 0-60 run today on a straight away and I punched it the whole time and I ended at 8.5 secs. I will do a 1/4 mile run tomorrow at the same location...
How does 8.5 sound for a 4.6L reg cab with stock engine and intake..
I havent had time to install my Volant yet...
