What are default settings for the EDGE?
Old May 28, 2006 | 10:51 PM
bamorris2's Avatar
What are the default settings for each Level? I've seem some posts by ASEMechanic about default shift points and rev limit, but what about the rest of the settings?? Like default shift firmness for each Level, timing for each level, idle speed, etc???
Old May 28, 2006 | 11:50 PM
expy03's Avatar
I just went through the manual and didn't see any numbers posted for the defaults.
I would assume that the numbers may be different depending on the hex code for the vehicle.
Good luck.
Old May 29, 2006 | 06:29 AM
C-17 Pilot's Avatar
Check out the first question on page 4 of the Edge Evolution FAQs located here: http://www.edgeproducts.com/pdf/FAQ_...n_Ford_Gas.pdf
Q: WHAT DOES IT (i.e., the Edge Evolution) CHANGE?
A:
The Evolution changes the following:
• Shift points (raised about 4%)
• Shift Pressures (raised about 8%)
• Ignition Timing (on levels 2 and 3 only)
• Fuel curves (on levels 2 and 3 only)
• Rev limiter (on High Performance only)
• Speed Limiter (on levels 2 and 3 only)
I know this isn't a complete answer to your question, but it's the best information I've found. :o
