Edge + Airaid = Terrible Drone
Old May 9, 2006 | 09:56 PM
Rocket951's Avatar
I am not sure if this is the correct forum to post this, but figured had to start somewhere . I have an 04 F150 w/5.4. Mods include Airaid Intake and recently bought an Edge Evo programmer. I had the Superchip 1714 prior to the Edge. Since I installed the Edge I have terrible drone/resonance from the Airaid at 1500-1800 RPM, with the Superchip I had some of the same, but never this bad. On the freeway even the slightest pressure on the gas pedal and the truck sounds like it is falling apart.
I am running the 87 tow tune on the Edge, with my standard shifting + 1 hoping to keep the RPM's up but that has not helped .
Anyone with the same setup that can help? Thanks!
Old May 9, 2006 | 10:25 PM
EVIL1's Avatar
Never heard of Drone comming from an intake?
Old May 9, 2006 | 10:41 PM
Rocket951's Avatar
Drone/Resonance???? Almost sounds like a 2 stroke dirt bike with a bad bog, if that makes any sense???
Old May 9, 2006 | 11:30 PM
SnowmaNick
Guest
Posts: n/a
I have the same setup. I have a bit of drone in that same area. I added a little dynamat on the heat shield and that helped it out a bit. Pain in the ****, but I place the fault more towards the Airaid than the Edge. I had this intake with a Hypertech and a Superchips (long story) same drone on all three.
