Changing the Shift Points?
Old May 2, 2006 | 01:29 AM
SilverBF150's Avatar
I am wanted to change my shift points for max performance.
The setting i dont know what to put is "Use Up/Down arrow to adjust shift points. Then Press Y to select or N to exit
1-2 Shift _ _ _ RPM"
then its says lower:
"1-2 Shift: +/- 500 RPM
2-3 Shift: +/- 500 RPM
3-4 Shift: +/- 500 RPM"
Can someone help me out?
Old May 2, 2006 | 02:24 AM
SnowmaNick
Guest
Posts: n/a
Lower RPM shifts generally are better for fuel economy and the higher generally are better for acceleration & performance. Start with smaller adjustments and, on the Hypertech first start off with just firming up the shifts. The firmer shifting is a noticable wake up call on the truck when WOT.
