horrible crappy gas mileage with edge....
when you cant help but hold it at WOT!!!!!
This thing was well worth the $$312 buckaroos i paid. This is how these trucks should run rolling off the assembly line.
I guess im not the only one who likes to see the IMPG go down to 2 when you punch it, lol Ive only used it on level 2 and I love it. Truck should come from ford like that. I love the downshift when you hit it from a roll
I automaticly put it on level 3 and promptly smoked the tires in the front of the house. I noticed a big difference right off the bat. When I was getting on interstate i floored it off the onramp..... i was stunned. traffic coming down interstate never got in front of me and i was doing a buck o five before i started to run outta room!! at cruising speed it uses less RPM. I can cruise 80mph and turn 1600-1700 rpm whereas before the program it would turn 2grand. I love it.
Unless you changed tires or gearing, you should be running the same rpm vs speed (in the same gear) as before. You might want to check the settings, you may need to change the tire size or the gear ratio or both.
Anyways, glad you like it.
I found it for $312 at truckracingparts.com, theyve got a coupon page you gotta go to......but it expires soon.
I just figured it took less RPM because it was making a little more power...i dunno, seems weird that it would change like that after i put the programmer on.
Is that what you did?
