EDGE Gauges
Old Feb 23, 2006 | 03:39 PM
Red05stx's Avatar
EDGE Gauges
I thought it would be interesting to discuss the details of some of the gauges on the edge. Most are self explanatory, but my question is about the MAF and MAFV. What exactly is it measuring there?
Old Feb 23, 2006 | 03:47 PM
MoJoe's Avatar
First off good idea on this thread topic! The manual goes into an overview of the parameters that are capable of being monitored, but for the ones that are not self explanatory, this will be a great thread.
MAF: is used to get a round-a-bout measurement of Air/Fuel ratios
MAFV: A voltage representation of MAF (from sensors) according to the book. For what this does, someone with more knowledge will have to answer on the benefits to this gauge I am guessing it is taking the information of the MAF readings and converting into voltage???
Old Feb 23, 2006 | 03:51 PM
Red05stx's Avatar
Ok so If my MAF reads 5.5 at Idle and jumps up to 13 at throttle, is that a good thing? what is everyone else getting on a 4.6 04 up? I seem to remember about 12 is normal?
Old Feb 23, 2006 | 04:21 PM
Robamus's Avatar
If its measuring the Mass Air Meter, then I would guess its showing the volts running to the mass air meter. Recalling my 5.0 Mustang days, the Mass Air Meter works by heating a wire element, and measuring how much power it takes to keep that element at a specified temp. As the air blows by, the wire cools, thus telling the motor there is more air flow... I think. Hope this helps.
Old Feb 23, 2006 | 04:57 PM
gobra's Avatar
Im guessing that you could plot the mass air transfer function using these coordinates. Thats what all the tuners play with i think... :-)
Old Feb 24, 2006 | 03:41 AM
Y2KWHT150's Avatar
While on the subject, I have ?? regarding Output shaft speed and Turbine shaft speed. According to the Edge manual, if OSS=TSS, tranny has no slip. Now I had it on when driving down the freeway today, noticed #'s began to different as speed was increasing. Now I'm hoping I am not having any problem with my tranny?
Old Feb 24, 2006 | 03:57 AM
Kool Aid's Avatar
You were in overdrive, right?
Overdrive is not 1:1, so the numbers will be different.
Try it again with the O/D turned off.
