Scanning
Old Jan 24, 2006 | 06:22 PM
02KR's Avatar
Scanning
If I am going to scan a budys truck, do I have to act as if I am going to program it, such as remove the fuel pump fuse?
Old Jan 24, 2006 | 07:54 PM
Former Sponsor
That depends on what kind of gear you are using the scan the vehicle - but generally speaking, no, you only have to remove the fuel pump & electric fan fuses (if so equipped) when you are actually going to *flash* the PCM.
Generally speaking, you can plug in an OBD-II and/or CAN-capable scan tool and read codes without any such issues as needing to remove any fuses. Just follow the instructions that came with whatever scan tool you are using.
I hope that helps, & good luck!
