Xcal2 and torque converter
Old Jan 18, 2006 | 02:38 PM
bvhall's Avatar
I also posted a similar thread in the 04-06 section, but was wondering if there is anything a program change can do for the problem?
I've been reading both here and in the tranny section, but still no real answer.
This 2005 transmission seems so different than the one in my 2002. I'm thinking its the torque converter. Its so much more obvious in the 05 -really feels like a 5th gear. The old one would lock/unlock nearly unnoticed, but this one is really obvious and annoying.
Seems like it locks up way to early and unlocks way to late. Feels like I'm driving an early 80's GM car with their OD tranny! (If you've ever been in one you'll know what I mean!). The slightest grade makes the converter lock/unlock constantly -doesn't come out of OD, but really feels like its 'hunting' between gears.
I'm using an Xcal2, by the way, and it really didn't affect this any differently than the stock program.
Is there ANYTHING that can control the RPM or throttle position that the converter locks/unlocks?
Old Jan 18, 2006 | 03:39 PM
jpdadeo's Avatar
I don't have that problem at all with my 04 Screw. Who tuned your XCal2?
Old Jan 18, 2006 | 03:43 PM
bvhall's Avatar
Its from Troyer. I tried to say that it acted the same before the tune too.
I re-read my post and it is a little confusing. The tuner didn't cause it, I'm just wondering if it can FIX it.
Old Jan 18, 2006 | 03:46 PM
jpdadeo's Avatar
Probably the best thing to do would be call Mike and ask him
Old Jan 18, 2006 | 04:38 PM
bvhall's Avatar
I talked to Mike and learned quite a bit! It seems to just come down to the lower power associated with winter fuel and the fact that the 3v 5.4's make very little torque arount the 1600-1800 RPM range this is happening at.
thanks Mike!
Old Jan 19, 2006 | 12:38 PM
Former Sponsor
You are very welcome!
IN this case, what he was doing was cruising at 55-60 mph in overdrive, and going up a grade, the TQ would lock & unlock, it was just at that load point and at such a low rpm that it would cycle - so in that scenario, at those low rpms, the hot tip is to just disable O/D and let the engine turn a few more rpms and eliminate the TQ cycling in that scenario.
Its' pretty rare, but it is possible at low speeds going up certain grades to find a certain amount of grade at very low rpms in overdrive where the TQ will unlock and then lock right back up once it achieves it's speed, but then once again not have the power to stay locked up going up a grade at such low rpms in O/D.
The winterized fuels reduce power by just enough to cause this in some cases as well, so just FYI for those reading, that was what the issue was about and some of what we discussed.
