Delphi 50lb injectors?
Old Dec 8, 2005 | 04:29 AM
badchargedboss's Avatar
I am upgrading my fuel injectors, so I can remove the FMU from my Vortech charged 5.4. I can buy the 42lb bosch injectors, but I have a friend with a set of 50lb Delfi injectors. I have the twin lightning fuel pumps, and Lightning MAF. Will I be able to run the 50lb injectors? Anyone else running them? btw, the charger is pushing 10psi... if that makes any difference. Thanks. -Rob
Old Dec 8, 2005 | 08:46 AM
Mickey_shouse's Avatar
i keep readin where lightning guys are having problems with the 50s so most just go with 60s. might get a good response to this if u post it in lightning forum, alot may not look at other forums much.
Old Dec 8, 2005 | 01:52 PM
Thanks Micky... good idea.
-Rob
Old Dec 8, 2005 | 05:22 PM
VortechSaleen's Avatar
Correction me if I'm wrong....but isn't a Lightening MAF factory cal'd for 42lb injectors? Unless there is a way to re-program the L-MAF (there wasn't when I was into it), it's not going to work w/ mis-matched injectors. I used to run the L-MAF and 42's on a previous Vortech charged stang.....it was a reliable combo which gave me best drivability results. In my case, if I wanted to go w/ 50lb injectors....I'd have to go w/ a universal MAF such as a Pro-M that can be cal'd accordingly.
Old Dec 9, 2005 | 06:36 AM
that makes sense
What about a combination of the lightning maf and the diablo MAF.ia? The mafia is designed so that you can up the injectors, without switching mafs. Anyone here try the Diablo MAF.ia?
Here is a link to the MAF.ia page...
Old Dec 11, 2005 | 09:35 PM
evo's Avatar
evo
I have a Sct tuner and a Mafxtender. I thought you could only use the MAfia if you have the Predator?
Old Dec 12, 2005 | 04:39 AM
I do...
The predator should be here this week.
