Got my 1714
Old Nov 29, 2005 | 10:56 AM
pit's Avatar
pit
Got my 1714
I received my tuner last night and rushed out and installed the 87 octane tune then took it out for a spin. I can tell you I am happy with the results, even on the 87 setting. The throttle lag improvement and firmer shifting alone made the purchase worth it. I want to install the 91 tune but I have a question, do I just run down the 87 octane in my tank until the check engine light comes on, then fill up with 91 and install the new program? My concern is driving any distance on the 87 tune with 91 octane in the tank, in this case from the gas station to my house to load the 91 tune. Should I first reload the stock setting then fill up with 91 octane?
Old Nov 29, 2005 | 11:16 AM
KD1's Avatar
KD1
Personally I would run a few tanks at the higher grade before switching the tune. Thats what I plan to do anyhow.
Old Nov 29, 2005 | 11:51 AM
05SilverFX4's Avatar
usiing the 87 tune with 91 in the tank is perfectly ok (you wont get any better performance though). never the other way around. It would be a good idea to run to less than 1/8 of a tank, then fill with 91 and drive a few miles to run the 87 out of the fuel system before loading the 91 tune. Good luck
Old Nov 29, 2005 | 04:07 PM
pit's Avatar
pit
Thanks for the replies...
I thought the user guide said something about not using premium gas with the 87 octane setting, perhaps I misread. Thanks again.
Old Nov 29, 2005 | 06:42 PM
jntwlsn's Avatar
I have been happy with my Superchips tuner except for one thing; the check engine light will not go off! I get a #P1000 code. I drove my truck for over 1000 miles, 13 hour trip included, for a hunting trip. On the way home, the check engine light came on. I drove another 10 hours sraight with the light on. Been that way for two weeks. Any suggestions?
Old Nov 29, 2005 | 06:48 PM
rawzon's Avatar
type P1000 in search, i found this:
https://www.f150online.com/forums/sh...ighlight=p1000
Old Nov 29, 2005 | 10:10 PM
pit's Avatar
pit
Hmmm....I haven't got a check engine light yet, did your come on right after installing the tune or did it take a while?
Old Nov 30, 2005 | 12:38 PM
jntwlsn's Avatar
The speed shop set the computer for me at HI-PERFORMANCE. I drove it for over a week commuting to and from work logging 400 miles. I then changed it to the TOW setting and then drove 13 hours straight to Oregon, while pulling a 16' fully enclosed utility tailer spanning 800 miles. Spent the week driving trails while hunting, 600 miles. On the way home, after driving 200 miles, the light came on. I re-set the computer 3-4 times this past weekend to 87-TUNE finding the shift points and pressures that suit my driving style. The light has been on for 2 weeks. So I guess I'll wait it out another week or so to see what happens.
Old Nov 30, 2005 | 01:12 PM
jntwlsn's Avatar
Thanks rawzon for the search. From what the SuperChip reads, the computer must re-learn the shift points and pressures. I am a little because it has been awhile.
