Well, Add me to the list
Old Sep 27, 2005 | 03:17 PM
dzervit's Avatar
Actually they delivered it to the right house. I just snatched it off his front porch before he got home from work... tee hee.
Old Sep 27, 2005 | 03:24 PM
RED WING NUT's Avatar
It won't do you any good. It's programmed for an FX3 1/2, not a 'Lariot'
Old Sep 27, 2005 | 03:25 PM
05SilverFX4's Avatar
They are running behind again, I called today and was told it would be another 10 bus. days..................that would make almost 5 weeks. Man, I need a drink
Old Sep 27, 2005 | 03:30 PM
dzervit's Avatar
That's why I ran over it several times after I discovered it won't work. I guess I could ship you the bag of plastic pieces and silicon chunks.
Old Sep 27, 2005 | 03:34 PM
I placed my order 9/07 and got email "on tuning desk" 9/12. email said I would recieve in 10 days to 2 weeks!
I ordered mine 8 days before you so it should be on it's way any time now. Right Mike?
Old Sep 27, 2005 | 08:25 PM
jpdadeo's Avatar
Is it going to have mako or is that program still on hold? I think it's still on hold
Old Sep 27, 2005 | 10:08 PM
No official word, but I would bet that is the reason for the delay.
Old Sep 28, 2005 | 01:53 AM
Maxx Roost's Avatar
I received my Xcal2 on Fri. Spent the weekend burning up the 87 octane in the tank so I could try the 92 perf. Noticed the the speedo is still way off and there was no on-board adjustability for tire size and gear changes. I read some posts about it and I'm sure I'll get the e-mail utility to fix the speedo.
Anyway I'm very impressed with the Xcal2 so far. I can't light the tires up for 15' like the guy's with the 04's and 05's but it will spin them for a little bit, not bad for a lifted truck with 35's. When I put the TP sticker on I'm sure that will add the HP I need to light em up.
The increase in power is noticable from 10% throttle to the floor, it's very cool.
Thanks to Mike and the TP team, Well worth the wait
Old Sep 28, 2005 | 06:32 PM
Former Sponsor
Hi everyone,
Yes, we're back to tuning using Mako, so those getting XCal 2's are once again having those options enabled on board - and as soon as SCT gets us the utility we've been talking about, we'll get everyone else with XCal 2's on-board adjustability emailed out to them!
For MAXX Roost - There is no reason your speedo should "still be way off" - if we got the data for the correct gear ratio & tire size on your CPW's, then that would already be plugged in, so you might want to give us a call on that so we can check into that for you.
Old Oct 14, 2005 | 08:32 AM
jpdadeo's Avatar
Originally Posted by Superchips_Distributor
(Snip
Hi everyone,
Any news on the progress of the utility?
Those XCal2 owners with mako, what different adjustability aspects do you have? etc
Old Oct 14, 2005 | 10:16 AM
kr1mson k1ng's Avatar
Congrats dude. I can't wait for mine!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
Old Oct 15, 2005 | 06:07 AM
I only looked through them once so I will try to remember:
Timing:
0-2000
2000-4000
4000-7000
global
Fuel:
0-2000
2000-4000
WOT
idle in neutral
Idle in drive
Gear ratio
Tire size
Speed limiter remove
Rev limiter adjust in gear
Rev limiter adjust in neutral
Shift pressure 1-2
Shift pressure 2-3
Shift pressure 3-4
I think that is it. I dont know the ranges of each one as I did not adjust anything. Troyer Tune is perfect. Never mess with perfection.
Data logging still requires a laptop
I hope this helps
Old Oct 15, 2005 | 09:45 AM
jpdadeo's Avatar
My guess is that the adjustments Mike has on there for you to use would still fall within a safe parameter
thanks 05
Old Oct 17, 2005 | 02:14 AM
HK308's Avatar
paperwork in on Sep.12.....feels like prom night all over again!! lol
still waitin to rumble
https://www.f150online.com/galleries....cfm?gnum=6623
