Odometer correction with 1714
Old Aug 14, 2005 | 07:35 PM
gobra's Avatar
I know the 1714 will correct the speedometer if you install bigger tires but will it also correct the odometer? Im just trying to measure my mileage with my new 18s.
Old Aug 15, 2005 | 08:14 AM
jpdadeo's Avatar
I *think* when the speedo is corrected the odometer is also calibrated to match
Old Aug 15, 2005 | 10:08 AM
gobra's Avatar
You could slow your speedo down and reduce the miles driven if that was the case i guess.
Old Aug 15, 2005 | 10:40 AM
RED WING NUT's Avatar
Yup. Just like puttin' on bigger tires and not calibratin' the 'puter.
Old Aug 15, 2005 | 10:50 AM
MGDfan's Avatar
Hi - to actually answer gobra's original question - yes.
The same correction factor is used by the PCM for the speedo and the odo.
Cheers
vic
Old Aug 15, 2005 | 05:54 PM
gobra's Avatar
That's what i was afraid of. My gas mileage took a hit with the 18s....
Old Aug 16, 2005 | 12:43 PM
Former Sponsor
Yes, any time the speedo is corrected, the odo is corrected as well - just as it should be, so the vehicle registers the basic correct number of miles driven.
Old Aug 16, 2005 | 12:48 PM
gobra's Avatar
One other thing, do you measure the loaded tire diameter or the calculated? I measured the tire to be 31 inches but a tire calculator says 32!! It is the 275 65 18 lariat 4x4 tire.
Old Aug 17, 2005 | 12:53 PM
Former Sponsor
Which ever gives you the most accurate reading, it's not going to make that much different, due to the compression of the contact patch and the fact that the resolution of those types of tuners is 1/- 1/4 " anyway.
Most people measure them loaded, measure a rear tire from side to side (not top to bottom), and then subtract 1//2" from that amount - and plug that in - that usually gets you in the ballpark.
