9400 tuner
Old Jul 28, 2005 | 02:29 PM
Horndoger2's Avatar
9400 tuner
Long time user, first time post.
I have an 03 F150 with code KGR2 and a Flowmaster cat back.
Question is: Will the "slowmaster" restrict any of the potential gains from a 9400 tuner? If so, how much of a loss, 1-2%
Thanks,
Horndoger
Old Jul 28, 2005 | 05:37 PM
jpdadeo's Avatar
Here's a little info on the subject but it's not specific to exact hp loss
Originally Posted by Superchips Distributor
(Snip
We test many parts for these trucks, as we do not accept manufacturers claims - many of them will say anything to make a buck, you know how that goes. Magnaflow simply does the best job in terms of not only peak HP gain, but most importantly, part-throttle torque at any rpm or throttle position, which is key for the drivability of these trucks - as you can see in the comment from the other post, Gibson, along with Flowmaster & many other exhaust brands, can actually cause a *loss* of part-throttle torque and torque at lower rpms regardless of throttle position, even though they do gain some HP at wide-open throttle - this is due to a lack of proper flow engineering to speed up the spent exhaust gases when upsizing the tubing diameter, and this loss of torque is a very common complaint among F-150 owners (and many truck & SUV models in general) who install cat-back exhaust systems, so the choice there is important. All of our vehicles wear Magnaflow - every single one of them - simply because it does the best job.
Old Jul 29, 2005 | 07:25 PM
Former Sponsor
Hi Horn,
Don't worry about that "Slowmaster" as we call them in jest - you are still going to get the normal power gains from pour tuning.
The only real difference is that you get the results on the EXHAUST side of things that are representative of the Flowmaster systems, that's all - and a LOT of people love how they sound.
What I generally recommend is that if you like how that system performs,s you just hang on to it and enjoy it! And worst case, if you feel you just *have* to make some kind of change, keep the system and just swap out to an appropriate Magnaflow muffler.
If you decide that you want to do something like that, you can always give us a call and we cna make some recommendations for you based on what system you have now, and the exact body style of truck and your preferences.
However, the bottom line is, that Flowmaster system is NOT going to cause you to NOT enjoy the results of our custom tuning - so don't you worry about that, OK?
