DTC code
Old Jan 14, 2005 | 09:24 PM
Robin's Avatar
Question DTC code
What dose this mean? It came up on my Superchips 1715 MAX Micro Tuner
P1635 Tire/Axle Out of Acceptable Range ?
Help thanks
Robin
Old Jan 18, 2005 | 05:29 PM
Former Sponsor
Hi Robin,
A couple things I need to let you know about, & then I'll get your answer for you............
The way to get Tech Support is described right there in your Micro Tuner's documentation - it tells you how to get help in several places, which is to call the manufacturer - or, you can call whoever you bought it from. That is the way to get Tech Support on virtually any product, and is usually the best way to get the most accurate information - just FYI in general.
You also want to get in the habit of using the SEARCH feature here any time you have a question - spend a little time learning to use it's search filters and look up the info you want rather than typing up another thread and having to wait for someone to see it and respond to it with accurate information. The search feature gets you *instant* answers to anything ever discussed here. There is virtually nothing regarding the topic of this section of the message boards that hasn't already been asked & answered here hundreds, if not literally thousands of times before - like your question, for example. Again, just FYI........
Now, to get you the info you need...........
In short - forget about it. In these FoMoCo vehicles you'll get that code when you recalibrate the speedometer - it's perfectly normal, so don't worry about it, just enjoy your vehicle!
Thanks for your post & have fun!
