top speed
Old May 23, 2001 | 09:23 AM
DEJ's Avatar
DEJ
Post top speed
I was wanting to know what the top speed is or would be for 2000 F-150 5.4 auto with a superchip install. I already have flowmaster exhaust K&N generation II and Poweraid TB spacer.
[This message has been edited by DEJ (edited 05-23-2001).]
Old May 23, 2001 | 05:41 PM
Neal's Avatar
Cool
HI!... 138MPH so far!LOL
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, PERMA-COOL external tranny filter, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings.
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.52E.T * MPH - 93.73 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
Old May 23, 2001 | 09:50 PM
XanMan's Avatar
Thumbs up
139 on dyno don't know on the street spedo pegs at 100
99 Black F150 4x4 4.2
Powerdyne SVO BD11-a Supercharger
12lb. of boost
24 psi.high flow fuel injectors
Port matched intake
Boost gauge 30"HG-20PSI A piller mount
Ram air intake
K&N air filter
JBA Headers
True dual exhaust w/Flowmasters(2 1/2 in. pipe)
custom programed Superchip(Flip chip)
All black factory sport package.
Rhino Liner
GTO smoke headlight&tailight covers
limo tint
Old May 24, 2001 | 12:31 AM
Former Sponsor
Post
Hi DEJ,
Welcome to F-150 Online!
The top speed with the Superchip and your other 2 mods will depend on the exact configuration of your particular F-150, as there are substantial weight differences between 2WD, 4WD, long bed, short bed, short cab, extended cab, Super Crew models, having the Offroad Package, etc., even with the same engine.
The top speed limiter is set at anywhere from 98 to as high as 108 mph from the factory, and these 5.4 trucks can go anywhere from about 115 to as much as 135 mph with those modifications, depending on it's configuration (which determines it's weight) & gearing.
Keep in mind that your factory tires are not rated for driving at speeds in excess of 100 mph for extended periods, so if you intend to do sustained high-speed driving, you'll want to upgrade those tires perhaps.
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
Old May 24, 2001 | 05:59 AM
evo's Avatar
evo
Post
120 mph, GPS on dash, had more pedal but shut down because of 109 tire rating.
Old May 24, 2001 | 02:29 PM
Former Sponsor
Post
Hey Xanman,
Ask Neal the HP Freak to tell you how to turn your digital odometer into a bunch of other gauges, one of which is a digital speedo that will read way over 100 mph, that's how Neal knows he's doing 138 mph.
As many times as it's been posted, I can't ever remember how to do it, Neal's the expert on that little trick.
Mike Troyer
(540) 862-9515
Old May 24, 2001 | 03:47 PM
XanMan's Avatar
Cool
Thanks Mike for the tip I'll have to get that from him. Talk to you soon.
12lb. of boost
Port matched intake
Ram air intake
K&N air filter
JBA Headers
Rhino Liner
limo tint
Old May 24, 2001 | 03:55 PM
fast54triton's Avatar
Post
Here ya go:
Put key in ignition
Press and hold TRIp/RESET BUTTON
TURN KEY TO POSITION BEFORE START
Once screen says TEST, let go and press it till ya see ENG 0000
