Super Chip Overheating?
Old Apr 19, 2001 | 04:37 PM
2001 F-150 SPORT's Avatar
Question Super Chip Overheating?
I just finished reading about how ford gauges are not accurate, and that due to this it is not possible to get any kind of readings other than extreme.
If you can’t tell what you motor is “really doing” then how do you know that a performance chip is not making you motor run hotter.
In the past I had heard that performance chips made the old 5.0 mustangs run hot and a bigger radiator was needed.
If the ford gauges don’t show changes that what the *******, how do you guys who have performance chips know that it isn’t hurting you engine?
Does any owner know for a fact that their engine is not running hotter?
Would this also apply to oil pressure?
Old Apr 19, 2001 | 05:06 PM
moose-man's Avatar
Post
An excellent question!
/me waits for Mike T to answer!
97 F150 Longbed V8 4.6
K&N air filter
K&N FIPK tech MOD & removed elbow silencer
Tires: Yokohama 265/75/16 Geolander AT+
Hyper white xenon bulbs
Bedliner and raven shell
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
[This message has been edited by moose-man (edited 04-20-2001).]
Old Apr 19, 2001 | 06:27 PM
Neal's Avatar
Cool
HI!... The SUPERCHIP DOES NOT effect oil preasure or engine temp. I have both a oil preasure guage and engine temp guage in my truck and have NEVER seen an increase in either. Actually I did notice that my engine temp dropped about 5 degree's after I installed my SUPERCHIP.
NEAL " THE H.P FREAK" E-MAIL :nnewman@sympatico.ca
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP "FLIP-CHIP", BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, PERMA-COOL external tranny filter, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS, FORD RACING 24LB injectors, RUSSELL stainless steel braided tranny lines with fittings.
FUTURE MODS : BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150 LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 340H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.52E.T * MPH - 93.73 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 16.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon JAZ fuel cell,etc
Old Apr 20, 2001 | 02:34 PM
Former Sponsor
Post
Hi 2001,
Just so you'll know, the Superchip does *not* make your engine run hotter than it normnally does without it. If it had any tendency to do that, with all the people using them this section would be flooded with those kinds of posts, and of course, we don't see those kinds of posts here for one simple reason, because that doesn't happen.
While these are not the most accurate gauges in the world certainly, these gauges are not so inaccurate that you cannot tell an increase in coolant temperature. The fact that they are not the most precise gauges does *not* automatically mean that they are completely useless and will only tell you the extremes. In fact, it's very easy to see what your temperature gauge does, how it reacts, etc., from the time you first start your vehicle when cold, and as it warms up, you clearly see the gauge start from the bottom and slowly come up to normal operating temperature, unless the gauge is actually broken, in which case that will be obvious. And it's also easy to see when you're running abnormally warm as well, these gauges are accurate enough to see that. You can easily verify that by spending some time observing your own gauge from cold start to full operating temperature, and you will also notice that there is a *range* as well.
This is a very basic issue, the Superchip is *not* going to make your engine run hotter.
It's true that these gauges, like most factory gauges, are not very expensive, and don't give you exact temperature readouts of course, and there are certainly more accurate gauges, thanks to the aftermarket. But they are accurate enough to tell whether you're running hotter than normal, we drive nothing but FoMoCo vehicles here and not one of them has a temperature gauge so inaccurate that you can't tell if you're running hotter than "normal".
If you'd like to go over this in more detail, please feel free to give us a call.
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
