6600 Installed
6600 Installed
Recieved my 6600 yesturday and installed today after work. Took about 25 minutes, real easy install.
I had Troyer put the following tunes on it:
1. 87 tow
2. 87 performance no tow
3. 89 performance no tow
4. 91 performance no tow
Right now I have it on #2 cause I have the 87 octane in it. Right after I installed it I took it out for a test drive. Seemed like the power increased a bit from stock and shifts seem a little firmer. Nothing head wrenching but noticable. Now I want to run the liquid out and put in some 94 in it to see what it will do. I did the 91 performance cause I will be retiring in the sw Washington State area in about 5 years and you can only get 91 octane up their, hence not getting the 94 which is available in Alabama.
I had it programed to correct for my bigger tire size as well.
So all in all very pleased.
I am going to keep track of my fuel usage as well and will post results. And I have been told that the longer you drive the better the performance ...
Thanks Mike!!
1. 87 tow
Thanks Mike!!
hey 2003 f150supercr this is 72 mustang i sent off my paper work thrusday for my 6600 i got 87 89 91 93 octane was the install of the 6600 easy and wher did you mount your control **** also did you mark on your sheet that you wanted your tranny to shift stock frim or hard (2002 screw 5.4) thanks 72 mustang
72,
Install was easy, your computer is located on the passenger side above the kick plate. I found the easiest way to get the computer out is to open the hood and take the battery out. Then take the battery tray out as well. This gives you straight access to remove the wire harness. Unbolt the wire harness first.
Then remove the plastic that goes in the lower passenger side door (foot sill), remove the fwd rubber molding and then pull the kick plate off. Now you will be able to see your computer mounted to the left side wall. Unsnap the clip and it should fall right out.
The rest of the instructions come with the 6600 and are easy to understand.
Reverse above to put back in.
On the shift I asked for Firm. I took it out today for a little drive down some country roads and stepped on it to see what it would do. Man what a difference from stock I am more pleased than the quick little drive I did right after I installed it..
You will love the difference...
Also forgot to mention the switch, I ran it up and into my glove box from the back, it is really a small dial switch. You dont even notice it. The computer is right in that area as well.
hey 2003f150supercr do you have the factory tires on your truck and i know you choose firm on your custom tune but do you have a shift kit or valve body just whanted to know i was thinking about doing one later but i will frist install the chip thanks 72 mustang
72-
I have th 305/70/16 tires, stock was 255/75/16 so a bit bigger than stock.
I would go with the hard tranny shift if your looking for that hard tranny shift kit style. I wish I went with that instead. My other toy-a 68 Camaro has the shift kit in it and it shifts hard and I like that feel. My trucks tranny is bone stock.
(had to mention the Camaro since I see you have a pony
