102 octane gas!!!!!!
Old Feb 6, 2001 | 01:45 PM
Wichita_Greg's Avatar
Post
Is that 102 Octane still UNLEADED ?
My company makes a high octane gasoline, but it is leaded, and will ruin Oxy sensors and cats.
Greg
'96 Triumph Thunderbird
'99 Ford F150 XLT SC 5.4
'00 Lincoln LS8
Wichita
Old Feb 6, 2001 | 09:16 PM
tfratzke's Avatar
Post
I'm with Wichita_Greg, the only 102 octane gas i've ever seen is LEADED.
Tony
Old Feb 7, 2001 | 12:53 AM
Stayblown's Avatar
Post 102 octane gas!!!!!!
To Mike, At Superchips,
I had a question about premium gas when using the super chip. I know that in order to get the best out of the chip one must run premium. In california that means 92. Well I live near Near a place that is used for diesel fueling and race car type fueling because they offers 102 octane. The brand of gas is from 76 which i already use only the regular 92. The gas is about 2.30 a gallon and if it is possible I would like to know if this super high octane will enhance the superchip even more than regualr 92 premium. Any opinions would be greatly appreciated
Old Feb 7, 2001 | 02:32 AM
Neal's Avatar
Cool
HI!... You can run 100+ octain with the SUPERCHIP but to get a bit more H.P and performanse you will have to have the chip calibrated for it or your just wasting your money. I have a flip-chip that when in "RACE" mode is set-up for 100+ octain (UNLEADED) race fuel. MIKE T set up my chip, so I would advise you to contact him about it. It is possibly to get UNLEADED 100+ octain racinf fuel but it is expensive. Here in CANADA you are looking at $400-$450 for a 45 gallon drum. You guys are right that LEADED fuel WILL damage 02 sensors and cats. Same thing applies to that 104 octain booster aditive. Hope this helps you out.
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old Feb 8, 2001 | 12:10 AM
Former Sponsor
Post
Hi Stayblown,
That's an excellent question!
And generally speaking, no, using 102 octane won't get you appreciably more power from the "standard" Superchip for your computer code, that is going to require a custom program to get more power from 102 octane.
Now what we can do is to make a custom program specifically for the use of 102 octane, and pull more power out of it like that. To do that, I would suggest using our 2-program Superchip Flip Chip, as you won't want to run that expensive 102 octane all the time, but instead, what you'd be better of doing is have one of the programs in the Flip Chip be aset up for 100+ octane, and then the other program set up for normal pump premium of 92 octane. That way, you can still run on pump premium and get nice power gains, and then when you want to, run the 102 and get the maximum power gains from it.
You might want to give us a call to go over all the specific details, that is what I would suggest, so we can cover all the bases and potential implications, what you're doing with the vehicle and what you want to be able to do, etc., we'll be happy to go over all of that with you.
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
