Fuel/Air Before & After
Hi Mike, I thought this F/A might be of interest to the board. The Custom Superchip is doing its job beautifully! The red graph is the same program but with the stock MAF and TB. When I opened up the intake with the Pro M 80 and BBK TB then the mixture was right on. The dyno guy called it classic!
I will be replacing the stock cats and modifying the exhaust between the cats and the Magnaflow. after that it will be back to the dyno.
98 White 4.6 Triton STX (It's not an STX anymore) Flairside,Class III hitch, Blue Cobra Stripes, Euro Lid by Astro, Bed Rug, Fiero Wing, Air Dam,Ground Force 2-4 Drop,Custom MB Phantom Wheels,clear corner lenses,monster battery terminals,MTX Sub Box with 2 10 inch Polk Subs, 4 Plok Speakers, MTX 102 Amp with Pioneer FH-P4400 CD Cassette Head Unit,Custom Programmed Super Chip,BBK 75mm TB, Pro M 80mm MAF,Pillar Pod w/ boost and trans temp,Jacobs DIS Ignition,Art Carr 2000-2400 stall transmission,4:10 gears,custom rear end housing, custom intake tube, Jet coated JBA stainless headers, Magna Flow Muffler with Stainless Duals and of course fully Blown by Magnacharger!
http://www.zing.com/album/?id=4293450711
[This message has been edited by Flats Man (edited 01-04-2001).]
I will be replacing the stock cats and modifying the exhaust between the cats and the Magnaflow. after that it will be back to the dyno.------------------
Hi Flats Man,
You're right, those A/F numbers in the 11.5 - 11.7 to 1 range are beautiful, that's right where you want to be with that supercharger.
It's "interesting to see that blue graph where it's at 14.7:1 at cruise (I'm assuming from our conversation yesterday), and when you punch it it goes right to the mid-11's where it should be @ WOT. Very nice.
Thanks for your post!
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
Mike Troyer
(540) 862-9515
