Dealer trip...pull the chip?
Old Oct 26, 2000 | 09:29 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Talking Dealer trip...pull the chip?
Hi MIke, I was talking to you on the auto popping out of second thread.. I have an appointment for tuesday morning to get my trans,leaky differential,and knocking engine checked out....Boy,when the trouble started,it happened QUICK! I should pull the chip out when I take it in,right? As for no other reason than preventing them from denying my warranty claims. I am praying my heavy foot didn't cause all this trouble. Once it's fixed,I promise to keep my foot off the gas...... (yeah right!)hehe. I'll probably get the plus 4's put in while their under the hood, They've been in the door pocket for two months and I'm itching to see the gains from them. ,,,,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Cobra 75WXST cb w/weather alert
Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good
On the way/wheels,tires,air dam, etc..etc.......
doin the monochromatic boogie
on the front end.Billet grilles on order
Hoping for deliverance from door crack hell.
Old Oct 27, 2000 | 05:00 PM
98SCREAMER's Avatar
Cool
Exactly as I thought,thanks. Now you just have to fly all over the country training techs to deal with the chips.....On second thought it "would" be easier just to pull it.......Let you know how everything turns out. Funny thing though, I tied back the harness that touches the a/c condensor
and it STOPPED THE BAD IDLE!!! I just sort of blew it off when I first heard of that solution, I didn't have idling trouble til a few weeks ago. So,it wasn't that important at the time. Boy did it make a difference! It was sputtering and weezing
and I pulled the wire back and it smoothed up immediately. TTYS,,,,98
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
Viper 500HF Security system
www.my-f150.com
Fender Guitars,ROCK!!!
Old Oct 28, 2000 | 12:31 AM
Former Sponsor
Post
Hi Screamer,
We do advise pulling the Superchip prior to service, but not because of warranty considerations. We advise this simply so that the technician doesn't have any problems when they connect your vehicle to the SBDS (service bay diagnostic system). Having the Superchip installed during diagnostics will not interfere with that process, but with the Superchip attached there will be another error code reported, it's a P0605 code I think, that tells the technician that the computers internal eprom chip is not functioning, and because it's not replaceable, to replace the computer! In other words, they think the computer has actually failed because that chip is not functioning, most techs do not know how that external override data path circuit works. You see, when you attach the Superchip, engaging the circuit tells the comptuer to turn off it's internal eprom chip, and to seek it's instructions externally, via the Superchip. So the factory eprom chip is not supposed to be working with the Superchip attached, that's the whole idea, to avoid using that factory program! Conversely, when you remove the Superchip, that circuit acts like an on/off switch, and turns back on the factory eprom chip.
Now with our vehicles here at Performance, we do leave our chips in, and I have gone in and personally trained the technicians at our dealership on what to expect and what to do about it, but that's because of who we are of course. Most people do not have the detailed knowledge of how all this works, so it's just easier to avoid a situation where you're in effect trying to tell a technician their job, basically, by simple removing it prior to service.
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
Old Oct 29, 2000 | 07:57 PM
Former Sponsor
Post
Hi Screamer,
You're right, and it's been awhile since we discussed moving that harness/wiring away, but it's been found to help the idle quality and overall power even a bit in a number of these vehicles, I'm glad you found that litle "trick".
Good luck!
Mike Troyer
(540) 862-9515
Old Oct 29, 2000 | 08:43 PM
98SCREAMER's Avatar
Post
Is it the moisture? or an unwelcome grounding at that point that causes that.
I noticed a small tab wrapped in the harness there, looks like it was attached
somewhere,then let go over time. Wierd thing is the truck will go back and forth between idle qualities,now. Spends more time idling well so I'm not complaining.
The transmission seems to act better now,too. It's not 100% better,but it's definitely better. Pulling the chip tomm. afternoon,for the dealer trip Tues.,,,,,,,,98
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
www.my-f150.com
Old Oct 29, 2000 | 09:25 PM
dtrosch's Avatar
Post
Can you post a pic of the harness you are talking about? Or maybe a more detailed description? My new truck (3k miles) seems to idle a bit rough, and I want to check your sollution before anything more drastic...
Old Oct 30, 2000 | 12:58 AM
98SCREAMER's Avatar
Cool
Standing by the pass. side fender, look between the valve cover and the fender well . If it's the same as the 98's,there will be a small silver can shaped container just above the a/c compressor. This will be the condensor. Just to the rear of this
(maybe resting on it) will be the harness in question. I tied it back with some tie wraps,to the metal part of the hose that runs to the rear of it. It's a little difficult if you have large hands(like me,lol) But it did seem to help the idle. Hope it's detailed enough,Let me know and I'll try to
take some pics(it's a pretty confined area)
Good luck,,,,98
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
www.my-f150.com
Old Oct 30, 2000 | 07:29 PM
dtrosch's Avatar
Post
That should be enough detail. I will take a look the next time I can in the daylight. Thanks!
~Dave
2001 SuperCrew Lariat 4x4
Black / Grey Leather
Class III Trailer Tow Group, 5.4L Triton V8, Limited Slip Rear Axle, Bed Extender, Cab Steps, Engine Block Heater, Radio, AM/FM Stereo 6-Compact Disc Changer, Skid Plates, Moonroof, Sliding Rear Window, Ford drop-in Bedliner.
ARE-Z Cap (Black).
TriBall hitch (bumper protection)
Planned Mods: SuperChip, K&N or Air-Raid intake kit; Outland Sport Bumper, Reese front hitch receiver, behind the grill driving lights.
Old Oct 30, 2000 | 11:00 PM
redlariet's Avatar
Post
I think I read somewhere they figure it's static from the compressed gas flowing through the metal dryer bleeding into the inputs of the pcm. I have mine tied back.
97 Lariet-sc-4.6-4x off road-auto-3.55 LS-
superchip-K&N-3"
pvc air box mod-Granetelli MAF
Old Oct 31, 2000 | 12:07 AM
Former Sponsor
Post
Hi Screamer,
It appears to be a grounding type of issue, from what I understand, though I am by no means an authority on this. Back when this was being discussed here on F-150 Online, it seemed that it was either a grounding or partial grounding issue, rather than moisture.
Mike Troyer
(540) 862-9515
Old Oct 31, 2000 | 01:26 PM
98SCREAMER's Avatar
Exclamation
Hey Mike, Well the trip to the dealer here in Birmingham was bad! Check out the
Long-Lewis thread in Engines for more details..Thanks for all the help...98
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
www.my-f150.com
