? for Neal
Old Sep 22, 2000 | 11:37 PM
F150Tony's Avatar
Post ? for Neal
Neal,
JMC suggested I contact you here. I understand that you have full (read real)gauges on your truck. I have a 97 5.4l that I will be installing gagues on. What are your normal (and hi) water temp and oil pressure readings? I'm on the fence for the 100PSI Vs. the 200PSI oil pressure gauge.
Personally, I prefer the Autometer 2-5/8" Sport Comps, and will be installing them low on the center dash (above the register vent cowling) Where are yours installed? If you had it to do over, would you still install it there?
Thanks!
Tony
Old Sep 24, 2000 | 02:39 AM
Neal's Avatar
Cool
HI!... F-150 TONY : I have installed 3 AUTOMETER "PHANTOM" series 2-5/8 guages. I have installed them in 3 individual AUTOMETER guage pods that go on the "A" pillar. The 3 guages that I have are ENGINE COOLANT TEMP, OIL PREASURE, and TRANNY TEMP. Right now I have only two of the guages hooked up and my oil preasure gauge just happens to be the one that's not hooked up. I am having a hard time right now trying to find a fitting that will connect my guage to the braided stainless steel line I am using, and still fit in my guage pod. For which guage for you to go with, I would go with the 0-100PSI. Our trucks will never make over 100psi oil preasure, so don't bother with the 0-200PSI one. I would suspect that out trucks don't make much more than 45 PSI oil preasure. My "POWER RANGER" only makes 85 PSI! As for temp ranges : My engine coolant tempurature usually runs between 180-192 degrees. That's with me using twin 16 inch electric fans. My tranny tempurature is usually around 175-200 degrees. It only gets close to 200 degrees when I am really beating on her. (RACING)lol!
NEAL [ the horsepower freak ] NEWMAN
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, modified POWERAID spacer, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan.
FUTURE MODS : FORD SVT 24LB INJECTORS, BBK 75MM THROTTLE BODY, AADI F1 RAM AIR HOOD, traction bars, and a KENNE BELL BLOWZILLA supercharger.
ESTIMATED H.P TO DATE : 345H.P / 425ft/lbs of torque.
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old Sep 24, 2000 | 09:50 PM
F150Tony's Avatar
Post
Neal,
Thanks for the reply!
You confirmed what I thought about the oil pressure. I just wasn't sure about how much pressure to expect from the crank driven oil pump.
I have the Hayden #979 trans cooler w/ 10" fan. I'm finding I only need that much cooling during the summers in Phoenix (>110F). In 100F weather, trans temp cooled to 180F (195F towing 2500lb). This week it has cooled to the mid 90's and trans has cooled to 150-165. The fan doesn't even come on anymore (Hayden electronic control).
Thanks Again!
Tony
Old Oct 6, 2000 | 01:30 PM
Former Sponsor
Post
Hey Neal,
A lot of people have asked, so I thought this might be right up your alley...
How about posting a new thread, telling everyone how to bring up those "secondary" digital gauges in the odometer display?
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
Old Oct 6, 2000 | 01:38 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Question
Boy,it would be sharp to have the gauges
in the dash where the factory ones are.
They would look sharp with the bezels
sitting against the white face gauges....
Anyone know if this would be possible,
without damaging the pc board on the back of the cluster?
98 F-150 4.6 Litre XLT2wd Ext. cab
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Westin nerfs blk .powdercoat
Clear front corners
Cobra 75WXST cb w/weather alert
Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good
On the way/wheels,tires,air dam, etc..etc.......
doin the monochromatic boogie
on the front end.Billet grilles on order
Hoping for deliverance from door crack hell.
