ANYONE KNOW WHAT THIS TROUBLE CODE IS?
Old Sep 11, 2000 | 12:17 AM
Neal's Avatar
Post ANYONE KNOW WHAT THIS TROUBLE CODE IS?
HI!... Well guys the "FREAK" needs your help. For the last few months I have been getting a trouble code showing up in my digital odometer when I put it in diagnostic mode. The code that keeps showing up is "5284". My 1st thought was to disconnect the + battery terminal to see if it showed back up on restart. I hesitated because I did'nt want to have to make my SUPERCHIP re-learn all over again. There did'nt seem to be anything wrong with the truck at the time so I never gave it another thought. Well this weekend that changed. While sitting idling in a parking lot the truck almost stalled a few times and even now runs very rough at idle. It also seems down on power slightly. So today I cleaned my ATS (air tempurature sensor) and my MAS (mass air sensor) with windex and a "Q" tip. Nothing changed. Then I hooked up a voltage meter to my TPS (throttle position sensor) and it read 1.00. I had set it about a year ago to 0.98, but it seemed to be higher now. I reset it back to 0.98. Nothing changed. I then re-cleaned my K&N FILTER. Nothing changed. I then looked very thourghly through my engine compartment, looking for anything that was unhooked or just not right. I found nothing. This is driving me crazy. I just installed new factory spark plugs about 3 months ago, so I know it's not that. Anyone else have the same problem? How did you fix it? What is the 5284 trouble code? THANKS - NEAL
NEAL [ the horsepower freak ] NEWMAN
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, modified POWERAID spacer, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan. FUTURE MODS : FORD SVT 24LB INJECTORS, BBK 75MM THROTTLE BODY, AADI F1 RAM AIR HOOD, traction bars, and a KENNE BELL BLOWZILLA supercharger.
ESTIMATED H.P TO DATE : 345H.P / 425ft/lbs of torque.
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old Sep 11, 2000 | 05:29 AM
F-trucks's Avatar
Talking
SORRY NEAL
I looked in my CHILTONS repair manual on these type trucks and there is not even a code in there close to what you said! but however the rough idle your truck is doing sounds like you may have a bad oxygen sensor? they realy make one idle rough and makes them sluggish feeling! and use a lot more gas than they suppose to! sorry i cant help you anymore! have you tried calling your local FORD dealer and asking the service man what the code meaned
Old Sep 11, 2000 | 06:20 PM
Dunbarton's Avatar
Wink
Neal,
Here it is:
Code 5284 = "catastrophic failure imminent due to too many mods, poor driving habits and Canadian fuel......."
Dunbarton "The Middle Aged Kid" '99 XLT SC SB 4x2 4.6 auto 3.55 ls The occasional Z-71 Eater! Wedgewood & Denim, SuperChipped, Airaid FIPK, HD electrical and cooling, power seat, Rhino Liner, Extang Classic tonneau cover, Mobil 1. Man, I got it all! (New Jersey)
Old Sep 11, 2000 | 06:28 PM
Bill Bateman's Avatar
Post
and a big ole lead foot...
Old Sep 11, 2000 | 06:29 PM
Neal's Avatar
Cool
HI!... F-TRUCKS : Thanks for the reply. I was also thinking that it might be a bad oxygen sensor. All the symptoms you describe are exactly what my truck is doing right now. A few months ago I tried some of that 104 octane boost, never again! It turned my spark plug electrodes all red and it ran like CRAP! Later I heard that those octain boosters can screw up your oxygen sensors. I'm going to call my dealer this week sometime and see if they now what the code means. My brother is a mechanic and he could'nt figure out what the code meant either!
Old Sep 11, 2000 | 06:43 PM
Post
According to the SAE standards this is not a valid code which could mean a computer problem. But, the third digit being a 2 says it a fuel system problem.
P0284 Cylinder 8 Contribution/Balance Fault
This is as close as I can find and I believe thats a fuel injector problem on number 8. But my Ford codes don't even list injector codes.
Old Sep 12, 2000 | 08:48 PM
Neal's Avatar
Cool
HI!... BILL : Thanks for the response. I went to the dealer today and their computer tech looked in their FORD code book and could'nt find any codes anywhere even close to the one that I am getting. He also told me that if any of the main sensors on the engine were to malfunction, that the CHECK ENGINE LIGHT would come on. I'm not getting any light! Today at JMC's house with my truck in neutral, my truck kept surging up to 900-1000 RPM. When I put it in gear it wants to take off at that RPM! This is driving me crazy! I'm going to make an appointment with the dealer in the next few days to see if we can get to the bottom of this!LOL!
Old Sep 14, 2000 | 12:24 AM
Post
the 2 in the third position means fuel system problem. the 8 in the second means cylinder 8.
that is unless your computer is making stuff up... :-)
Old Sep 15, 2000 | 04:24 PM
JMC's Avatar
JMC
25 Year Member
Post
Neal,
5284 is an oil pressure switch failure.
Regards
JMC
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
Borla Cat Back, Headman Headers,
Modified Air Cleaner Outlet Tube
and air box, Shortened MAF sensor tower,
K&N air filter,
Superchips
Old Sep 15, 2000 | 05:14 PM
Post
The oil pressure switch makes it run bad?
Old Sep 15, 2000 | 06:05 PM
Post
In case anyone wants to learn about trouble codes start here:
http://www.obdii.com/dtcanatomy.html
Be sure to go to the home page.
Old Sep 17, 2000 | 11:54 AM
Bill Murray's Avatar
Really Old "Member"
Post
Thanks Bill for that Website intel.
Now, with all these neat sites being put out, AOL is giving me fits with OBD codes that apparently relate to them thinking that I have totally overloaded my "Favorites" domain.
And......their Service Department is no more helpful than the one at my Ford dealership!!
Bill
Old Sep 17, 2000 | 11:26 PM
Neal's Avatar
Cool
HI!... Well guys, "GOOD NEWS, GOOD NEWS"! Yesterday I decided to try and fix my exhaust leak. The flange that meets my header collecter was leaking slightly. After trying to unbolt it and try a new position, the re-bolt it up, it would still leak slightly. I got fed up with it so I took a flat punch and a hammer and slowly worked my way around the exhaust pipe flange, closing up the 1/16TH or less gap that was creating my exhaust leak. It worked great, and now I don't have ONE bit of a leak. But that's not the good news! Tonight when I got home I decided to check my DIAGNOSTIC MODE on my digital odometer, and guess what? The "DTC" (detecting trouble code) mode is now reading "NONE". I think what was happening was that the MAF sensor was telling the computer what amount of air was entering the engine, and the 02 sensor, because of the exhaust leak was disageeing with it. They were basicly disagreeing with each other. Now my truck seems to be running correctly and the idle does'nt seem to be surging anymore. We'll see if it stays like that now. I'd thought I'd just let you guys know what seemed to work for me.
Old Sep 18, 2000 | 07:50 AM
Way2Big's Avatar
Thumbs up
Neal-
Glad to see your trouble free again! Best way to fix things is with a hammer, hehe!!
'98 EB Expy 4x4
5.4L 3.73 LS
Trail.Tow & Skidplate Pkg.
DA MODS....
** Custom Fab. 4" Cold Air Enclosure
** Pro-M 80mm MAF w/Filter & SC cal.(Enclosed)
** WMS Velocity Tube
** 75mm Edelbrock/BBK TB
** Hand Ported TB/Intake Elbow to match
** Magnason/Eaton M90 Supercharger
** Autometer Boost Gauge w/ A-pillar mounted pod
** Cust. Prog. Superchip
** JBA Jet Black Ceramic Coated Headers
** Stage 8 Locking Header Bolts
** Gibson Sweptside Catback
** IPD Rear Anti-Swaybar
** Bilstein Shocks
** Manik Grill/Brush and Rear Taillight Guards
** PIAA 520 Foglights
** Clear Corner Lens
** Stull Billet Grill and Bumper Insert
** Ford Molded Mud Guards
** Ford Hood Guard
** "EXPEDITION" Receiver Cover
COMING UP NEXT, IN THE FUTURE....
** 4.10 gears
** Brembo Crossed Drilled Brake Kit
** 18" Wheels, due to Brembos
** F1 Cobra style hood
"Its Sooo Big...Its Gotta to be Blown!"
Old Sep 21, 2000 | 01:04 PM
Former Sponsor
Post
Hey Neal!
Congratulations on finding the problem!
From our discussion, that makes perfect sense, I'm glad you were able to get this solved, that it was "just" an air leak.
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
