chip for 96 4x4 302
Old Apr 17, 2000 | 11:58 PM
964x4's Avatar
Question chip for 96 4x4 302
mike, i just recently lifted my truck and i noticed a power loss after, what im asking is would a chip help me regain some of the lost power i am also going to be adding an airaid or fipk just not sure which one. do you or anyone have a prefernce as to which one i'll gain the most from ? any info that anyone can tell me would help out a lot thanks again jimmy
p.s. cant wait to meet you and everyone at the norfolk rally
1996 F-150 4x4 302, 3" body lift, 33s BFG All Terrain K&N air filter
future mods: airaid ant superchip
www.zing.com/album/?id=4294576377
Old Apr 18, 2000 | 11:26 PM
964x4's Avatar
Thumbs up
Thanks Mike i have to work tommrow (wed) so i will be calling you on thurs to talk thanks again and ill be talking to you real soon
jimmy
Old Apr 19, 2000 | 12:06 AM
Former Sponsor
Post
Hi 96 4X4,
Yes, the Superhcip sure will help with adding some power, 20 horsepower and 30 lbs./ft. of torque on the 5.0 engine.
When you lift these vehicles, they are of course higher in the air as a result, and that increases it's aerodynamic profile, or coefficient of drag. The vehicle being up higher makes it feel like you have less power, as it takes more power to push that taller vehicle through the air. The engine hasn't actually lost any power, it's load has been increased substantially. Most of the time when people lift their vehicle, they also install taller tires too, and that compounds the situation by effectively changing the rear gear ratio to one that is numerically lower. What that does is force the engine to operate below it's power band, and as a result both performance and mileage suffer noticeably. I see in your signature that you have 33" tires, and that is certainly big enough to be forcing the engine to work below it's normal power band.
There are a number of questions I will need to ask you in some detail, so I would suggest just giving us a call at our number below, and we'll be happy to go over all of this with you in detail, ok?
With regards to which airbox elimination kit to use, both the Airaid and K&N's FIPK kit give the same results, and cost the same, so it gets down to a matter of esthetics, mostly. Some people prefer the power-coated metal airtube used in the Airaid kit, and I must confess that I like it's looks a bit better myself. Basically, either kit will work well, cost the same, and give you the same power gains.
Just give us a shout, and we'll be happy to help!
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
Online Superchip ordering system:https://www.f150online.com/scpp/index.html
Old Apr 19, 2000 | 01:03 PM
Former Sponsor
Post
Hi Jimmy,
Anytime is fine, there's no rush.
All the best,
Mike Troyer
(540) 862-9515
