superchips vs. others
Old Mar 2, 2000 | 05:24 PM
jarrettruelz88's Avatar
Question superchips vs. others
What is the difference between what the Superchips chip does for transmission performance and what other computer chips do?
Old Mar 2, 2000 | 07:05 PM
Steve g's Avatar
Talking
Mike : ... can help you, more than i i have only had one other chip it was a jet and it was a junk i had to remove it do to check engine lights and severe drivablity problems.
I would buy another superchip with out a doubt.
*2000 blk xlt f150
*5.4 4x4 3.55 ls
*sc orp pkg
*tow pkg, 17 inch wheels
*herculiner,remote start
*flowmaster, air box mod
*bfg ko's A.R.E. cap
*sony 10 disc cd player
*k&n air filter
*superchip
****mods to come*********
harley davison hitch reciver plug.
removing stock cab steps& installing westins.
Old Mar 2, 2000 | 07:10 PM
fast46triton's Avatar
Post
Well for one, the Superchip works all the time, unlike the others which only work at WOT {wide open throttle}. This gives you better mpg, more performance, etc.
Old Mar 2, 2000 | 09:02 PM
Former Sponsor
Post
Dear jarrettruelz88,
That all depends on exactly what vehicle we're talking about. If it's the late-model F-150 V-8 automatic, the Superchip: Removes the upshift delay signal that elongates and softens the upshift. This reduces slippage and aids transmission longevity as well as improve shift feel and acceleration. It eliminates the engine power reduction during and after the upshift, which is caused by transitional spark retards. It also increases line pressure, but not by much, about 20%. Just enough to make the shift execute quicker and a bit firmer. These changes make quite a bit of difference in the feel & operation of the transmission. The transmission shifts quicker and firmer, but it is still very smooth on light throttle. The upshifts get progressively firmer as you give it progressively more throttle. Most other chips only increase line pressure, and do nothing to remove the power-robbing transitional spark retards or the shift delay signal. Something else you get only with the Superchip is the removal of the *downshift* delays, and again, the transitional spark retards after the downshift. For example, let's say you're cruising on the highway at 65-70 mph or whatever, and you romp down on the gas to pass another vehicle; with the factory program, there is a .75-1.5 second downshift delay, and then the power is also reduced for the next 400 rpm after the downshift. The result is poor performance in that situation, making you have to plan your passing moves carefully and well in advance. With the Superchip, the downshift delay is removed, so it downshifts almost immediately, and there is an increase in power rather than a reduction in engine power as the spark retards are removed. So it downshifts very quickly and pulls hard immediately. In other words, it enables much better "point and squirt" moves when the situation arises. There are other areas that are addressed only by the Superchip, but it's to much to go over here in this forum. Please feel free to give us a call if you'd like to discuss this in greater detail.
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
Online Superchip ordering system:https://www.f150online.com/scpp/index.html
Old Mar 2, 2000 | 09:04 PM
Dustoff's Avatar
Wink
Fast...are you planning on putting one in your 99 'Amazon Green' truck? I think you had one in your previous F-150 (if I am not mistaken)...this way you just might be able to pass that PINTO!
Like Fast pointed out and from my research..he is 100% correct.
And as always...Mike...the superchips guru *is* the true expert!
2000 F-150 XLT, 4x2, 5.4L Supercab, Styleside, Black with silver two-tone, 3.55, class III towing package with heavy duty cooling package, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
[This message has been edited by Dustoff (edited 03-02-2000).]
Old Mar 7, 2000 | 08:23 PM
linedog's Avatar
Post
I just installed a flowmaster40 ser with 3 in pipe to exit out the right rear and it sounds great..however I would like to get a chip for it and iam confused,is the super chip the same as a jet chip?I hear everyone raving about this superchip..what is the part # and where do I order one..I have a 2000 f-150 supercab shortbed 4x4 with a 5.4L and auto trans...thanks in advance
Old Mar 7, 2000 | 09:14 PM
88daman's Avatar
Exclamation
Hi Jarrettruelz88, cool handle.
Superchip definitely sounds like the way to go. I've been reading the posts to this site for some time now, everyone is totaly satisfied with the mod. I am sold on getting one as soon as the F150 I've ordered shows up, 8 weeks and still no build date .
Mike, I hope you will hear from me soon!
On Order: 2000 F150 4x2 Lariat 5.4L SC FS.
For Sale: 1995 F150 SC FS Loaded w/ Mark III Conversion.
Old Mar 9, 2000 | 12:38 AM
Former Sponsor
Post
Dear Linedog,
No, the Superchip is *not* the same as a JET chip, or any other chip. The Superchip is by far the superior product, which is why you see almost everyone using a chip here using the Superchip. There are very big differences between other chips and the Superchip, but it's too much info to go over here briefly, so you might want to give us a call, and we'll be happy to go over all this information with you.
The Superchip, unlike other chips, is programmed individually for each specific vehicle, depending on which software revision was loaded into your vehicle's computer from the factory. This yields a much better product that does far more for the vehicle, instead of the "generic" programs you get in other chips.
To locate your vehicle's computer code,. simply open your passenger door, and look in the front part of the door frame. In between the door hinges there will be a sticker with 3 letters and a number on it, something like ATC2, CPE2, etc. That identifies your individual vehicle's software revision, and allows us to program *your* vehicle specifically.
Mike Troyer
(540) 862-9515
Old Mar 9, 2000 | 12:41 AM
Former Sponsor
Post
Dear 88daman,
Wow, 8 weeks and still no build date. Well, once you get it it'll be worth the wait. From looking at your signature line, looks like you have a very nice 95 there!
Good luck with your new truck,
Mike Troyer
(540) 862-9515
Old Mar 10, 2000 | 06:47 PM
Dustoff's Avatar
Thumbs up
Installed my superchip today..and I am already one happy camper! Well worth the money and I already highly recommend it! It really does work as advertised!!
2000 F-150 XLT, 4x2, 5.4L Supercab, Styleside, Black with silver two-tone, 3.55, class III towing package with heavy duty cooling package, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99, Superchip now installed..WOW!!!!
Old Mar 10, 2000 | 06:53 PM
Lightningquick's Avatar
Post
Same here.The superchip is the ultimate computer chip.Mike troyer sent it out to me ,I recieved it in a few days.If you are going to buy a chip............SUPERCHIP PERIOD!!!!Much firmer shifts, no more bogging. More power than you could ever expect from just a computer chip!!
