Where's the code? Mike?
Old Feb 20, 2000 | 05:01 PM
silverback's Avatar
Post Where's the code? Mike?
I remember a thread regarding the computer code on the passenger side door regarding 97 F150's. I checked both side and nothing....I can see a sticker (or what's left) it useless. Where else can I get the code? Can I pull the kick panel off and get it without removing anything?
T
Old Feb 20, 2000 | 07:13 PM
fast46triton's Avatar
Post
You might want to check the drivers side kickpanel. Its the only way I believe.
Old Feb 21, 2000 | 01:27 PM
Former Sponsor
Post
Dear Silverback,
Sure, you can always go to the computer itself. It's mounted so that most of it is in the cabin, and it's just above the passenger's kick panel. You'll see that it is held to it's mounting bracket by a black clip, which is a pressure clip. Just pull that clip off, as the other post suggested, and you can see on the back of the computer where the clip was covering, there will be yet another sticker with your computer code on it. Also, you can go to the wiring harness, which will be right behind the battery on the firewall. It will have a black "cap" on it, with a single 10mm bolt head dead-center. There will be another code sticker on the front of the computer where the wiring harness connects to.
Just remember, it will always be 3 letters and a number on that vehicle, like YSL2, HAL4, IMP4, DJJ3, etc., there are a dozen or more codes for that year alone. Let us know if you have any more trouble locating your code!
All the best,
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
Online Superchip ordering system:https://www.f150online.com/scpp/index.html
Old Feb 22, 2000 | 12:55 AM
cphilip's Avatar
Post
Under that black plstic clip up under the passengers side. Slide your passengers seat all the way back get down uner there and look up on the side fire wall. Metalic box with a black plastic clip on the front. Slide the clip down and there she is. A sticker with bar code and three letters and a number. Look at Dukes "how too" for a picture of it.
Old Mar 2, 2000 | 12:03 AM
silverback's Avatar
Post
Mike-
I assume after moving the clip...boy that was easier than expected and this is what I found. I believe the first number is the one you say I need however here they all are....
TBL2 (this is it right?)
F75F-AMC
Tim
1997 F150 4.6L, 305/70/R16, American Racing Baja 16X8's, Flowmaster 50 series, 3" cat,3.5 Suspension Lift kit, Tinted Windows
Old Mar 2, 2000 | 12:55 AM
Lariat Ryder's Avatar
Wink
Hey silverback, TBL2 is the computer code you're looking for.... it's in the big bold print! The code is 3 letters followed by a number.... mines is CPE2. I have the lid to the cap that I pried out of my computer. You may also want to check out "Dukes" site. He has a How-To-Install a Superchip step by step page with pictures and everything! I looked over it a couple of times and installed mine in 35 minutes.... http://bloodog.com/superchip.asp . Mike's GREAT, and you can trust him completely.... hands on and very compassionate about his work and the people he helps.... Truly!
2000 F-150 Lariat 4x2 SB,SC,Styleside,Amazon Green/Clearcoat Metallic,5.4 Liter V8, Class III Tow-Package,3.55 Limited Slip Rear,Bug Deflector,Duraliner Bedliner,Superchip,K&N Filter.
[This message has been edited by Lariat Ryder (edited 03-02-2000).]
Old Mar 2, 2000 | 11:55 AM
Former Sponsor
Post
Dear Silverback,
Yep, TBL2 is your computer code, congrats! That code is for a California emissions-equipped vehicle, as a matter of fact. That code is ready anytime you are, and lots of people in California with that code are using the TBL2 Superchip.
Mike Troyer
(540) 862-9515
Old Mar 2, 2000 | 04:38 PM
silverback's Avatar
Post
Bought the chip this weekend will tell.....I must agree Mike truly is a class act. Following many threads of other members and watching his responses made me confortable in purchasing the product. I know I will not be left to hang. Cant wait I'm itching to put it in!!!!!!!!!!!!!!!!!!11
